Page 3 of 22
Re: What have you done to your slick today??
Posted: September 7, 2012, 5:09 pm
by Toyz
Re-installed the side toolbox (mostly). Looks good IMO! Trying to decide whether to do the Ranger seats in the longbed. I really like this truck but probably will not keep it, so I am not sure I want to use my pristine Mustang seats in it, or save them for the 61 uni, which is definitely a keeper. Either way, I've got to find a console, and the "correct" early style is easier to find than the later Falcon/Comet app, at least around here. I have a nice seat from a later crew cab which I've had in the longbed, may just stay with it. I'm thinking of putting the Fatman- fronted 65 together "patina"- style, utilizing the 66 shorty cab and sheetmetal and my stroker windsor. That would get the engine and transmission in service before they deteriorate, and give me another drivable option, as well as buy time to re-prime paint and re-assemble the 65 shorty!
I just need less thinking and more working hours!
Posted: September 7, 2012, 9:14 pm
by HiBoy63
Washed the 65 for a local high school car show tommorow. On the 63 nada the cab is still sitting in the middle of the garage waiting for me to get motivated to work on it again. Temps outside are getting cooler so time to get the welder out and get going.
Posted: September 10, 2012, 9:12 am
by bruceandersson
I spayed al's bedliner on my '65 short bed. Like the product, the gun settings are a little troublesome.
Posted: September 10, 2012, 11:07 am
by Toyz
bruceandersson wrote:I spayed al's bedliner on my '65 short bed. Like the product, the gun settings are a little troublesome.
Could you elaborate a little? I need to purchase a gun, and have little practical info to go by.
Thanks,
Posted: September 11, 2012, 1:04 am
by Harper
stopped by a junk yard on my way in from work and scoped out a set of 90's aluminum wheels, possible Explorer upper/lower EFi intakes!
Posted: September 13, 2012, 11:39 am
by Harper
picking up some .023 mild steel welding wire, as mine (11lb spool) has been sitting for over 4 years and has aquired some surface rust, which has caused it to hang up when trying to use it...new wire should fix this issue.
also i picked up my cross braces for my bed (they were also blasted and epoxied!
Posted: September 13, 2012, 12:48 pm
by Lowell
Getting ready to pull tranny and bell housing, got a tooth or possibly teeth of the flywheel. Starter just whizzes. At least ive got a spare flywheel with hopefully a good ring gear.
Posted: September 13, 2012, 12:55 pm
by Toyz
Hung the tailgate and mocked up the front end on the longbed, still got mixed emotions on the grille sans rabbit-ear turn signals.
Posted: September 13, 2012, 1:56 pm
by MadMaxetc
Been home sick the last few days...bad news for the bank account. NPD, DC, Summit all got a few hundred bucks. Should make for some good progress pics!
I also have been planning out a lot of parts on summits website using the wish lists.
Posted: September 13, 2012, 2:11 pm
by Kid
Paul. I like the front end of the 65s without the turn signals above the grill. My 65 is that way, it looks so much cleaner on the front without the signals sticking out.
Posted: September 15, 2012, 4:46 pm
by Lowell
Got my 65 back on the road today. Used the flywheel ring gear from a spare 240 engine i have ,and installed a new clutch while it was apart. I then found that the starter was bad also, so used one from my parts truck. Might be speaking too soon ,but so far the clutch hasnt chattered.
Posted: September 15, 2012, 6:19 pm
by Alan Mclennan
My passenger side door (L/hand door), has been giving me some trouble for awhile now, first off it was the power window not working properly, and then the door it self wouldn`t open!!!!. So yesterday took her out onto the driveway and had to crouch on the pas side floor and put my arm up into the door and feel around for what the problem was, I managed to get the door open and found that the central locking actuator had slipped it`s clip and was holding the door in the lock position.
Next problem was the window not working, I have one of those electric window switches that use the crank handle and so far after pulling it out and then dismantling it and putting it back together, where it seemed to work only to hook it up to the door again it stopped working!!
, so today I`m going to rig up a test board and put it through its paces.
Well that will be after we go over to one of the daughters places to get an old lounge off her for Miss Tazzie to sit on!
so atleast Lenore can do some work!!
Posted: September 15, 2012, 6:35 pm
by Harper
removed my front bumper, grill, radiator core support, inner fenders and front fenders...and all wiring under the hood. Man 47 years of it being assembled and rusting is NOT fun when tearing it apart, i just thank GOD I am in an area that's not a MAJOR rust belt... my GF helped me! a special thanks to her!:) oh and btw we just finished and are about to get showers....at 12:11 am
Posted: September 15, 2012, 10:09 pm
by Brians1966
Let my son take the Slick to work, got this text from him
"Darn Dad I'm a small celebrity in the Slick, Well Done!"
Made my day.
Posted: September 15, 2012, 11:11 pm
by Alan Mclennan
Brians1966 wrote:Let my son take the Slick to work, got this text from him
Made my day.
Of cause!
Posted: September 16, 2012, 9:17 am
by Harper
removed the two front access covers to access the front cab mounts,vacuumed out the 47 years of red alabama Dirt, WD 40'ed the bolts and the two front cab to frame bolts
. also removed some of the previous owners handy work with floor repair...screwed in sheet metal (both sides). I am beginning to think this is about to turn in to a FULL Resto...
this afternoon, removed seats, fuel tank, headliner, inside rearview mirror, working on removing the dash etc.. now..
Posted: September 17, 2012, 7:27 am
by White97
I resisted soaking it in gas and setting it on fire!
Went to install my new rad I got off eBay, over an 1" too narrow, flanges don't match. Put old one back in now dealing with vendor. Took it on another shake down run, driver side front caliper locks up. By the time I get back to the man-cave smoke is billowing out of the wheel well. Stopping today to order two new calipers. I'm wondering if this ever be on the road!
Posted: September 17, 2012, 8:16 am
by Toyz
Drove the towtruck over 400 miles, (of necessity, it proved to be too heavy for my car hauler). Changed a fuel pump in Coffeyville KS, then found the eccentric appears to be a problem, then installed an electric pump, got it running good until near Tulsa. It then appeared to run out of fuel on any incline causing a load. I bought a bigger pump in Tulsa, installed it; hit the turnpike running well, then symptoms recurred. Ran the winch cable out, hooked on to the towtruck, and made it to our exit in that manner, which attracted the attention of an officer sitting on the next entrance ramp. I saw his backup lights come on and back down the entrance he went. I then lost track of him until about 5-6 miles further. He pulled up beside me, moved up beside the pickup and trailer and then made a U-turn. He had called the next town over who were setting beside their cars waiting for us. Very nice officers, we talked for sometime as to legal implications; one officer stayed with us as we unhooked (I had told him I would just drive the truck slowly until we found a Motel!) I told him he didn't need to stay, as I probably had more emergency lights than their three cars!, but he stayed, and we had interesting conversations about winch cables, snatch webbing, Jeeps and other mutual interests.
We are now in Southern Oklahoma, and I'm trying to decide whether to press on, or head home and return with a bigger trailer.
Naturally, didn't accomplish much on the other slicks, but sure saw a bunch up close. There were more than 20 in attendance with only 5/6 members noted.
I'll post pics when I eventually get home; there were a bunch which should have been at SlickStock, including several that surprised both Ezer and myself with their choice of drivetrain
Ya'll have a great start for the week from deep in the heart of OKLA)(HOMA!
Posted: September 17, 2012, 8:30 am
by jkimbrel65
adjusted the carbs and went on a nice ride.
Mike
Posted: September 17, 2012, 8:54 pm
installed a new ignition coil, set the points and tightened the fan belt.
put on new front springs before i left Alaska and found the 3500 mile trip toasted the insides of my front tires so next up is installing the 2 new tires i brought along and adjusting the toe. supposed to be toe in slightly not toe out.
