Plastic fuel tanks
Plastic fuel tanks
anybody know of any underbed plastic tanks that would work with a bed fill?
Ryan
351w/Aod
351w/Aod
- in2hotrods
Custom Classic Trucks mag did a tech article a few issues back using a "universal" tank (steel though...). perhaps this may give you some leads and ideas as a "between the frame rails" install is pretty generic.
the link: http://www.customclassictrucks.com/tech ... index.html
perhaps a swap meet alternate: my 66 longbed came with fiberglass auxiliaries from an outfit out of Fort Worth, TX that has since gone out of business. they were ahead of the rear tires, outboard of the chassis rails. about 10 gals each with fill necks accessible through the wheel wells. pretty sweet install strategy as an alternate idea for keeping the spare tire between the rails, out back. my longbed tanks would definitely not work on your shortbed though - takes up the entire space.
good luck!
good luck!
66 F100 longbed, 240cid all in a line, rowing thru 3-on-the-tree
