anyone make their own HEADLINER?
- Nick64Slick
well its about time to start finishing off the interior and I was wondering if anyone had any luck making their own headliner? I was thinking about getting some poster board and making a pattern and then cutting it out of something more substantial.... my roof has been pie-cut and lowered so it does not have the approx. 1" step up like stock 64-66s do, but if someone has a pattern it would still be a good starting point. I'm open to suggestions.
I made mine out of Thermo-ply (a structural cardboard like material $12 for a 4X8 sheet from the local lumber yard) using an old headliner as a pattern. It was fairly easy to work with and I am pleased with the outcome. I glued vinyl to it with contact cement and fabbed some hidden clips for the front and rear to replace the original clips.
Take a look in my album.
Doug
Doug
- Nick64Slick
choptopdoc
Thanks guys, I didn't keep the old panels. They were just pieces of the original that I soaked with water so that they would lay flat and pieced them together, filled in the gaps and added in where needed. After a trial fit before gluing on the vinyl I had to do some triming. I also had to score the Thermo-ply along the radius of the bends with a utility knife to help make the correct bends. It's a job that requires a little bit of help when
installing and fitting.
The clips were made from 3/4 & 1" banding strap, it can be bent to shape and it has some spring to it. I used pop rivets to secure them to the panel before I covered it. The jute on the backside of the panels takes all the tinny sound out of the cab.
I haven't posted pics of the panel behind the seat, I removed the gas tank, installed a Mustang tank in the rear and made a panel to go around the back of the cab. I'll get pics in soon, right now I'm trying to get on the road. I can't wait to see how that CVPI frt suspension handles!!
Doug
Doug
- Nick64Slick
thanks Doug, definitely interested in seeing the back panel also when you post pics, I too relocated my tank so I'll have to do something similar but I know what you mean about getting it on the road first. another thing we have in common is the CV front end and I cannot wait to take it out as well! I was lucky enough to drive JFCDeuce's slick before he got rid of it and man is the CV nice! a bit stiff but the steering and ride are completely different then a stock 60s truck and I thoroughly enjoyed it! good luck man, keep us posted. I'm almost done as well, its just too damn hot here to keep my same work ethic.
Anthony
here is mine..... http://fordtruk.com/forums/viewtopic.ph ... c&start=60 .... scroll down to about the bottom of the page. It is not for everyone but It looks great in my Slick...
[albumimg]8059[/albumimg]
with a little patience and creativity you can build one. Just take your time....
