Independent front suspension
I'm looking at pulling the front axle on my '64, in place for a independent front suspension. Any of you guys/gals that have done this swap have any suggestions on which set up to buy? I like the No Limit setup but also considering the Fatman Fabrications setup. Any suggestions? Thanks!
Re: Independent front suspension
Voodoo around here the most popular options are the Dakota kit from Steve at Industrial Chassis or the 2003 and up Crown victoria front clip.
- jkimbrel65
x2 on the dakota.Drives like its on rails
Mike
Mike
I tried being normal once...
x3 for the Dakota. Super solid install. The front 1/3 of my frame could withstand a bomb blast now
- 64low-n-slow
Voodoo
I have a Mustang II kit from TCI and am happy with it, but agree with the others, Dakota and Crown Vic are MUCH more popular around here...probably better for truck applications as well. Knowing what I know now (and considering I scrapped a PERFECT CV setup), I would have used it and saved lots of cash. Whatever you choose, move the axle centerline forward 1/12".
Good luck.
Good luck.
Only thing I'm worried about with the Dakota kit is that I will be running a 4.6 and worried about the A/C compressor and Power Steering pump, with how low they hang on the engine.
Well shoot if you are running a 4.6 then the 03 and later crown vic is a natural choice ( the motor will bolt right in )
I have a Camaro subframe in mine with a 4.6 DOHC engine. The a/c and p/s isn't a problem at all and I would assume that the crossmembers would be located pretty close to the same place. I like the a/c & p/s down low because they aren't hardly seen.
The only conflict that I had was the p/s box. The pump was real close to the box but I guess that the Dakota has rack & pinion so that shouldn't be a concern.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
63BIGWINDOW
We've used Brents(fatman) and Robs(no limit), and had great results with both.My 63 shop truck has a camaro clip with a 460 and has well over a 100k and 2 decades with no concerns ever. Do your research though there are down falls with all your options, the crown vic works great unless you want it loooww, and you can live with the wide track width, done a couple of these and they are great for a small budget. Havent heard alot about the dakota setup, only a few concerns about the bolt pattern is all , looks like a similar price range to most MII based kits.. My personal favorite is the NoLimit wide ride, its way beefier than a standard MII type setup and it isn't for a tight budget build but worth it in a performance build...JUST REMEMBER EVERYONE IS FULL OF OPINIONS so do your research and get the best for you , your budget and abilities.
63 big window shop truck
93 2wd lightning/bronco-wifes driver
- Total Gearhead
3rd times a charm? Started with the Aerostar... not low enough. Went to the MII. got it low enough but bump steer. Now I'm going with a Trans Am clip. It will sit right and handle the way I want it to. I'm building a Pro Touring truck. I want to be able to drive the wheels off of it. Now that I have a Firebird rear end in it I'm past the keeping it all Ford stage of my life. Still running the 3rd motor as well. Started with a 69 302. went to a 74 460 now I have a 91 5.8 FI motor in it. Had a 4.6 but never did anything with it. Kind of happy with the direction I'm going now.
aka "Horsepower"
61 F100 Step
"One Step Closer to the Edge!"
http://www.hubgarage.com/mygarage/TotalGearhead
http://www.myspace.com/totalgearhead
dub@thetotalgearhead.com
http://www.facebook.com/group.php?gid=214833125322
If it has a motor or wheels I'm in!
61 F100 Step
I haven't seen one in person, but from all I've read and heard, the Dakota kit seems to be extremely well designed with a lot of attention to detail & strength. As for the bolt pattern, this kit seems to be one of the easiest to remedy. If you want the 5x4.5 Ford car pattern, just use the stock Dakota components. If you want to match the original 5x5.5 pattern, just get a set of rotors from the correct full size Dodge, which shared that same pattern with Fords.63BIGWINDOW wrote: Havent heard alot about the dakota setup, only a few concerns about the bolt pattern is all , looks like a similar price range to most MII based kits.. .JUST REMEMBER EVERYONE IS FULL OF OPINIONS so do your research and get the best for you , your budget and abilities.
