brake lines
- therealjoeshmoe
brake lines
what size is the metal brake lines on our trucks?
Re: brake lines
mine was 3/16ths
- bobenhotep
Re: brake lines
Mine was also all 3/16.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
- therealjoeshmoe
Re: brake lines
OK THANKS I GOT 20 FOOT OF 3/16 BRAKE LINE FOR $12 IS THAT GOOD DEAL?
Re: brake lines
I'd say that was a fair deal. You have a double flaring tool and tube bender to make your new lines?
on a 74 chassis, 390, C6
A work in progress
A work in progress
Re: brake lines
Learning to double flair is fun. I squeeze the line holding tool in a couple of C clamps. Makes it a bit easier. Don't forget to put the fitting on first.
William-in-St. George
Re: brake lines
Do yourself a favor and spend the money for the Eastwood flaring kit. Makes factory looking flares with ease.
Use a little bit of brake fluid when you make your flares, it works as a lubricant and will make a nicer looking flair.
Simon
65 f 100
65 f 100
- therealjoeshmoe
- PFM-64f100
Re: brake lines
or you can convert to AN (37 degree) fittings (AN-3). I find they are a lot easier than 45's and it is a single flair not a double flair. Plus getting pre made AN-3 hoses from speedway is quick and cheap.
- therealjoeshmoe
Re: brake lines
I JUST BOUGHT A DOUBLE FLAREING TOOL THROUGH MY WORK SO WHEN I GET THE CAB OFF AND MOTOR OUT I WILL DO THE BRAKE LINES... THANKS FOR THE ADVICE IM SURE ILL NEED MORE!
