I know I've seen a repair piece for the front of a styleside bed, made to replace the bottom part of the front panel . The piece that seems to rot out on all these trucks. I can't seem to find it in any of my catalogs. Will be calling Tom at Flashback this morning to se if he has it, if he doesn't then I still will need the information. New parts are coming out all the time for these trucks , I will someone would make the front support and repair pieces for the flat corners. The whole front panel would be nice also.
Who makes it?
Re: Who makes it?
sOk, I give up. Can't seem to find this piece anywhere. I may have had a brain fart, and was thinking of the patch panel for a flareside bed.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
Re: Who makes it?
Some one makes it but I believe it's listed for a bronco if that helps
Re: Who makes it?
If you remember where you saw it, or think you saw it, please post. Although, I know where this would be used on a bronco, do you?kelwar wrote:Some one makes it but I believe it's listed for a bronco if that helps
1961 F350
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
- olliesshop
Re: Who makes it?
Probably too late, but I could find one either so we're having to fab one up. On mine the very bottom 1/4" or so has holes in it. Hopefully it will be done in a week or so. BTW, the portion right behind the front panel is a completely rebuilt Torque Box, which was completely rusted out.
Tim - 1961 F250 Uni
Re: Who makes it?
I used the hole bed floor and vertical front panel from a Chevy truck bed I got cheap . Fenders were bent up but the floor was nice. Cut the back of the cab under the belt and installed the front panel and floor. Look like it came that way from Ford.
