"Any Y-Block Photo's?"
Shadow
Post by Shadow »
Been Really Working On Cleaning Up Under The Hood. Here's A Before & After Pic's. Would Really Like To See Photo's Of Your Y-Blocks! Image Image
Re: "Any Y-Block Photo's?"
it was here resting for several years before i ended up using it
now
first slick right after i brought it home 2001
Post by Gritsngumbo »
Before:
After:
63 F250 Long Flareside
Shadow
Post by Shadow »
Great Photo's Brian & Gerald. Even With A Dry Top-End & Krusty As Hell Mine Still Ran When I Got It. These Motors Are Just Amazing! More Photo's Please..........
rderr
Post by rderr »
Before
After
charliemccraney
Post by charliemccraney »
cars2cool
Post by cars2cool »
charlie - I can see some sweet modifications done to your y-block, would you care to tell us some details about it? Like where did the valve covers come from and your ignition upgrade and where you got the alternator brackets from.
'31 Model A pickup, '55 F100 Yblock w/fordamatic, '56 F100 6cyl. 3 spd. BBW my first pickup bought when I was 13 in 1974, '77 Lincoln Town Car with 64,000 original miles For Sale
charliemccraney
Alternator bracket and valve covers from John Mummert, http://www.ford-y-block.com. The valve covers do not come with the breather holes. I drilled those.
The distributor is a Duraspark distributor that fits a Y block. There's nothing particularly special about it. It's a fairly easy modification for a factory distributor but mine uses an actual Duraspark body. The whole ignition system came from Performance Distributors, distributor, box, coil, wires, and wire dividers. I made the brackets for the coil and wires. I don't think you can get the distributor from them. It was a unique situation but all of the other stuff is universal. http://performancedistributors.com/
Shadow
Post by Shadow »
Great Looking Motor Charlie. Are Those Headers Ceramic Coated?
charliemccraney
They are. Those are Red's Headers.
