'61-'67 Econoline rear axle fit an F100?
Does anyone know if Econolines and Ford F100s shared the same 9" rear end?
1966 F250/352/cruiseomatic tranny/Dana 60 4.10
longcabjohn
Re: '61-'67 Econoline rear axle fit an F100?
I think the Econoline had the 4 1/2 bolt pattern same as car
Johnny
Johnny
Truckfarmer2
If you found a parts Econoline, consider getting the gas tank. It has the same dimensions as the Mustang tank some of us use. The van tank has the filler neck on the side instead of middle like the Mustang.
