Is anyone using stainless studs or bolts?
I hate to have a set of nice painted manifolds with rusty hardware.
I read that some use stainless studs with brass washers and nuts.
Exhaust Manifold Bolts
Re: Exhaust Manifold Bolts
many good reasons to use stainless hardware. sooo much easier if you ever need to remove the manifolds, and they do look better. tsc has a good selection, at least in our local store.
Truckfarmer2
Make sure you use Anti-seize compound any time you use stainless steel or any time you use disimiliar metals together.
Anytime I install exhaust manifold bolts I use anti-seize . I once read where someone used something else that supposedly was used in boilers. I'm thinking it was milk of magnesia, but not positive on that.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
