headliner
1965 stepside
headliner
Been awhile since I posted on this site I mainly am on the Facebook site.any way does anyone
Have a downloaded plans or drawing of a headliner with measurements? I have material to cut out my headliner but could use a pattern to make it easier. It is for my 65 . thanks for anyhelp.
Re: headliner
I have templates,made from a 66 four piece install.Paper,can roll up in a tube and send USPS.
Re: headliner
i used my old headliner to make my new one, made it so much easier. i did make some extra braces so it'll not sag like the origional did.
1965 stepside
Re: headliner
Mr. Jones that would be cool. How much?I know I sent a pm but was before I found the reply button.
Re: headliner
What do you guys make/cut your new headliner out of?
Did you glue it, screw it or how did you attach the new headliner?
Does anyone have pictures of their new headliner?
BarnieTrk
BarnieTrk
Re: headliner
I'm getting ready to tackle this in the next week or so. I think I'm gonna make mine out of closed cell foam that wont hold moisture and glue it right to the top of the roof after I've covered it with the headliner fabric. I'm going to extend the top section all the way back to the rear of the cab and make the piece that fits above the rear window sit vertical instead of at an angle and it will probably be made out of fiber board and covered to match. If possible, I might make the two curved side panels part of this piece to keep seams to a minimum.
Re: headliner
I was going to post a new thread about my headliner. I just have to say that I'm very frustrated with the cardboard kit I got. I thought I was being very careful putting it in, soaking with water as I went, but I'll be damned if that long skinny piece didn't crack in half around the hole for the light
I"m sure others have done it right but I f-ed it up.
Re: headliner
I helped Richard Beck install one of his,we laid it over the top of the cab then missed it with with water until it shaped itself
- F7BIGJOB
Re: headliner
I've done 2 65's and 2 52 Ford headliners all bought thru DC over the years, and never heard of wetting them until I saw it on this site a while back. Mine did not seem to come with instructions, did them by myself no issues.
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
-Steve
Re: headliner
Why couldn't you you this method with a sheet of 1/8" ABS plastic using a heat gun to shape the plastic. I haven't tried this but but it seems like it should work close enough to get it mounted and then use the heat gun for final shaping inside the truck.unibody madness wrote:I helped Richard Beck install one of his,we laid it over the top of the cab then missed it with with water until it shaped itself
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
Re: headliner
I believe that is basically what Blaine at Roddoors did/does.
Re: headliner
Plastic with the heat gun is what I was going to try on the Turk project.
I traced Richard Becks' new headliner, on the box it was shipped in... the box however got "recycled" on trash day, so I am back to square one on finding a pattern.
