Rear Bumper AND Roll Pan
jghelm
Post by jghelm »
I recently picked up a '64 long box that had a huge wrap around utility bumper on it that I recently removed. A local old timer sold me a rear bumper off of '63 that bolts up and will fit with some additional spacers. I like the way the bumper looks besides the large gap. Has anyone out there done something similar and closed the gap? I was thinking of possibly a roll pan with slots cut for the brackets to go through. Any pictures folks could share is much appreciated!
truck rear bumper.jpg (178.76 KiB) Viewed 1167 times
truck rear bumper 2.jpg (203.35 KiB) Viewed 1167 times
Re: Rear Bumper AND Roll Pan
welcome~!
Where you located? I actually have a 64 rear bumper I am wanting to give away if someone is close enough. I have a flareside so don't need the styleside bumper. I think the 63 and 64 bumpers are different. the one I have looks different.
jamesdfo
Post by jamesdfo »
I believe that bumper came off a Uni (or a wrongbox?), which is why it looks out of place on a Styleside
The one I'm assuming you want looks like this
kstones63
Post by kstones63 »
I put a roll pan and a bumper on my 63 just because I didn't want to see the gap between the bumper and the tailgate.
It took some work to get it this tight. The inset on the bumper hit the roll pan so I had to make a recess in the roll pan for the bumper to clear it. In the first pic you can see the recess for the bumper.
Was it worth it? It was to me and I would do it again.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
Leeroy
Post by Leeroy »
Your fab work still blows me away kevin!
Looks good!
Jghelm
With the correct 64-66 bumper the gap is nowhere near as bad.
This is how is should look, and you can see the problem Kevin was taking about
