I could not believe the article I found on yahoo...
https://www.yahoo.com/finance/news/junk ... 00603.html
The comment section has both informed fans , and morons ! hahahahahah
Re: I could not believe the article I found on yahoo...
What about the poor 1961 owners, what generation are they?!?!?
Wow, what a shame it ended up in a pick n pull yard, that truck was totally saveable!!
...but if it was much, much closer, I'd be in there harvesting the cab & front clip to help bring my crew back from the brink:):)
James
James
I either set the record straigh or I shamed us all. I could not remember for sure if Unibodies included 1961 so I left that open. The windshield looks right to me unless it has been replaced and the 64-66 replacement windshields resemble the earlier shape somehow.foodstick wrote:https://www.yahoo.com/finance/news/junk ... 00603.html
- Gravemetal
That truck is in way better shape than mine is
I think the windshields are the same.. however it appears to be a 61-63 cab above the drip rail, could be my eyes.
The steering column is a Twin I-Beam column. That truck was set up to use as a truck. Not many half tons have trailer brake controllers. It does not look like a repainted truck. The paint on the steering wheel look like factory.foodstick wrote:I think the windshields are the same.. however it appears to be a 61-63 cab above the drip rail, could be my eyes.
Xx
and the shape of the inner fenders also indicates it's a Twin I Beam truck.....
Webfoot wrote:You can tell that it is either a 1965 or 1966 by the front I Beam suspension visible in the pic of the left side.
From what I can see, the floor is flat like the 65-66 the drivers side fender had a 65 emblem on it. The top of the emblem outline at least appears to be from a 65. The 66 emblem would have the F100 incorporated in the emblem. Of course the twin I-beam is visible.
1966, but heater hoses are backward, and that disc brake rotor is undersize!
After I zoomed way in I can see the taller cab, looked like a 61-63 until I zoomed in..
- 6166 Junkyard Dog
if you look at the pics under the hood you can see 2 items that where on 66 trucks, 1 item was maybe used on late 65 trucks sometimes but not on the 65 trucks are on the other and on D/S the emblem has the imprint of a 66 emblem since it will say FORD across the top,
Kathy
Now Cooper will try his best
Good eyes,Tom!
