what is this button do?
WAY2FASTMIKE
Post by WAY2FASTMIKE »
hey guys,
i have a 1966 f-100 longbed. it has a push button right above the key ignition, any body know what it is or what it does. oh yea i'm keeping my truck now. got it running good now.
thanks
mike.
mikecarson
Post by mikecarson »
Optional ejection seat.
Mike C
64 CC, Crown Vic project
62 CC
67short 94 F150, 433W
Paul Merrell
Post by Paul Merrell »
Hey Mike maybe I could stop by your house I live in Wilson near Nash street and Airport blvd I could take a look if your truck had clearance lights I would say it was the blick switch or it could be something a PO installed.
mikecarson
I think it's for the windshield washer.
Mike C
62 CC
DanSanDiego2000
Windshield Washer Button........
Post by DanSanDiego2000 »
Almost without a doubt, it is the windshield washer button. Provided your truck has the washer nozzles on the hood, the bag and bracket on the inner fender well, the pump on the inner fender well, etc.,..... it was the washer pump switch.
I went to a great deal of trouble to round up all the original items to add washers to my otherwise poorly optioned truck. I think whoever ordered my truck new would have opted for no engine if they could have saved a buck that way. Needless to say, the Windshield Washer option was not one of my truck's original items, but it sure is nice to have now.
If you determine that yours is the washer pump button, it may not take much to get your washers working again.
Good luck.
reeses66ford
Post by reeses66ford »
IT IS FOR THE WINDSHILD WASHER IT WORKS ON MY TRUCK!
reese
jimbob1021
Post by jimbob1021 »
some had them some did not it is for the winshield washers i had a 65 and a 66 that did not have it i have a 66 custom cab that did have it but that part is missing :?
Mazlem
Post by Mazlem »
Mine had the button but it had been wired by somebody to be the ignition starter, (key provides power, button starts it up.) Has anyone ever seen that before, or only for the windshield wipers?
DanSanDiego2000
Starter button
Mazlem, I had heard of that spot being used for the starter button, too. I just wasn't sure where I had read it, or what years/models did that. It may be that your truck originally was wired for that to be the starter button. You can probably tell from your ignition switch. If the ignition switch only has OFF position and RUN position, then the START feature had to be accomplished by the secondary switch.
Maybe it was the earlier '61-'63 or '64 that was like that :?:
Someone here must know the particulars.
WAY2FASTMIKE
same
hey paul, i live off of air port also, we may be neighbors, landrum dr cant miss my old truck.
push button
Normally you would see those buttons used as starter buttons on the 48-52 F-1s. My 61 unibody had the regular ignition switch that was used on all the Slicks. I'm not saying a p.o. didn't wire it up like that, though.
Wouldn't put that past them. It's no telling what you will see on these trucks when you buy one. If you are lucky, you will get one with the wiring harness intact and working. My 61 had the squirters on the hood, but it was a custom cab. I sure miss that truck.
SoonerStateRedneck
Post by SoonerStateRedneck »
Yea, On my 66 F250 its for the windshield washer....but on the my 65 its my horn button! :wink:
64 f100
Post by 64 f100 »
Rare option for Nitrous injection. Don't push unless safely straped in.
Rich :D
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Mazlem
Re: Starter button
Post by Mazlem »
DanSanDiego2000 wrote:Mazlem, I had heard of that spot being used for the starter button, too. I just wasn't sure where I had read it, or what years/models did that. It may be that your truck originally was wired for that to be the starter button. You can probably tell from your ignition switch. If the ignition switch only has OFF position and RUN position, then the START feature had to be accomplished by the secondary switch.
The wiring in my '66 has been hacked up a bit, so I couldn't say what's original anymore. When I got it there were aftermarket squirters on the hood but no tubing and no bag.
The ignition is a generic switch put in by a previous owner. The wiper switch appears to be original, but only used for the wipers, not the washers as the wiring manual would suggest, (wires from the switch go to the ignition, ground, and wiper motor only.) I think when I put in a new ignition switch I'll wire the button for the washers.
SCWIDVICIOUS
Post by SCWIDVICIOUS »
my button is for spraying oil on the road so the bad guys cant catch me.
ohhh wait, mine dont even have that button...
1965 F100, 352, Cruise-0-Matic
William-in-St. George
Washer Button
Post by William-in-St. George »
And if you want to give that poor old switch a well deserved break add a 20 amp relay in the circuit to do the work and save your switch.
When you have 90% of what you want, think twice about insisting on the other 10%! Thomas Sowell
mr .c
Post by mr .c »
windshield washer on my truck
1965 F-250
300 cid
T-18 4 speed
Dana 60 rear end
