Ready to wake up from hibernation?
NY, NJ, PA, DE, DC, MD
66fordtrucknut
Post by 66fordtrucknut »
I know the snow flakes are still flyin up north, but I'm seeing the geese flying north so spring is around the corner, Good thing I just got done insulating my garage. I'm ready to fire Eunice up go for a spin. So whats up?
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
Red62Uni
Post by Red62Uni »
same here charlie just got done with insulating as well.
Next my uni might go to the paint shop for some room in the garage and a friend is extremely slow but i am trying to hold him off until next winter.
But while the uni is still here lets get some trucks out and blow the dust off them.
1962 F-100 Unibody All Original minus repaint
65 Mustang Fastback
68 Mustang Coupe (my baby)
79 Trans Am
racerx1699
Post by racerx1699 »
I'm dropping my frame off for powder coating on Friday, will be a long slow process putting it back togeather (Money)
Donnie
2011 F150
32 Ford Coupe
1985 Mustang 10.50's 1/4
1997 F350
If it wasn't on 8 Track it's not worth listning too
66fordtrucknut
Well I guess 3 of us are still around
62' SWB uni 223
DV65CustomCab
Post by DV65CustomCab »
Every time I think it's getting nice enough to get it out, it snows again. :?
Stop The Longbed Hate! :)
Now: '93 F150 Lightning
imstobu
Post by imstobu »
Pulled my F250 out today since im getting spring fever and found all kind of things wrong with it, bummer. Guess I have some work ahead of me. But boy am I getting the itch to do some cruising. now both of my 66's are down, plus my 66 t-bird has been down since december. better get busy. :roll:
66fordtrucknut
Cool , up to 5. I've been playing with the Mustang. Gonna try firing her up this weekend, hopefully.
Charlie
62' SWB uni 223
Fanatic
Post by Fanatic »
Well I want to take alittle ride too. But they keep spreading that liquid rust contributor anytime its NOT snowing.
Wont be long we will be bitchin its TOO hot
Tim
66fordtrucknut
Well, tried to fire up the Mustang tonight, I think I have the wiring right. Put a batt. in it.. nothing. with the key in run I get juice on the I post of the solenoid, when I turned it over to start had juice at the s post and starter side of the solenoid. But nothing from the starter and don't hear any clicking fr the solenoid. tried jumping over the solenoid and nothing. How do you check a starter? You know my vast mechanical skills.
Charlie
62' SWB uni 223
Red62Uni
Post by Red62Uni »
Charlie,
the only way i know how to test them is pull them off and bench test them. let me know whats up i think i got a couple extras laying around.
65 Mustang Fastback
79 Trans Am
Fanatic
Post by Fanatic »
Charlie, before you remove the starter, just hook a jumper cable to the starter cable on the solenoid and touch it to the + terminal on the battery. This will bypass ALL other wiring. Starter should turn over motor. Make sure you have a good engine ground. Even hook the other cable from "-" terminal to engine block.
If it still doesnt turn over, then its time to remove the starter and hook the cables from the battery to it. Make sure you have it held down because it WILL take off if its working.
Tim
66fordtrucknut
Thanks Rob and Tim, will give it a try, will report back later, if I don't drown in my yard. Animals are starting to line up in pairs outside of my boat.
Charlie
62' SWB uni 223
292fan
Post by 292fan »
Well me and the 64 are woke up. Just been running her to keep limbered up. Had to make some room for another addition to the collection.( nothing got sold). Picked up a 60 f100 longbed with a 223 i6 and factory 4 on the floor.(goes with my 60 Galaxie) Needs cosmetics but body is straight and it runs and stops good. Only rust is on drivers fender. Will keep posted on the progress. Steve.
Red62Uni
Post by Red62Uni »
i went and looked at 65 352 4 spd long bed custom cab today but the truck was a project but not too bad but i dont need any more projects but for 500 bucks it still looks like a good deal if anyone is interested i will pass on the info just pm me. the guy is moving to colorado so he needs to get rid of it. he probably flexible on the price some too.
65 Mustang Fastback
79 Trans Am
Rustbucket
Post by Rustbucket »
Charlie , Also before you take it off. Try lightly tapping on it with a hammer. Might be stuck from sitting so long. Sounds like the solenoid may be stuck to. You should have heard it click. Deal with the starter first though. Dale
1965 F-100 Shortbed 351W.
1969 F-250 Camper Special
1984 Mustang Convertible
1949 8N Tractor
needmoretime
Post by needmoretime »
I am awke!
New paint guy looked at the bed so that is lined up. Still working on John H. He wants as much done to it as I am willing to do. I am willing but don't have that kinda time. It is coming along.
Field trips this spring will be:
Fazio's
Bernvlle
Fanatic
Post by Fanatic »
Let me know when the Bernville trip goes down. I sure would like to make one.
Tim
Red62Uni
Post by Red62Uni »
field trips are fun just let me know when... wait a second... do i need a chaperone?
65 Mustang Fastback
79 Trans Am
66fordtrucknut
I took the starter off, stuck it in a vise. tryed grounding the case and touching the hot post with jumper cables and nothing, so tried it with a coupla old starters I had around and still nothing, I'll get a spark but thats it. If the starter I took off is messed up that would suck because it looks brand new and never used.
Charlie
Maybe I should just fix the rust, I know how to do that
62' SWB uni 223
jwh f-100
Post by jwh f-100 »
I'm ready. Looking forward to a MAC event. My truck went for some paint work today. (finally) He is going to paint everything under the hood, behind the grill, and the back side of the cab.
Here is a few pics,
http://i269.photobucket.com/albums/jj59 ... tts008.jpg
http://i269.photobucket.com/albums/jj59 ... tts006.jpg
http://i269.photobucket.com/albums/jj59 ... tts001.jpg
P.S. I am getting back some venison kielbasa this week and I'll save a few rings for the MACsters.
Jason
Beer will change the world.
I don't know how but it will.
