Late model three on the tree trans?
I have a plan to put an efi 302 in my 62, but I want to keep the column shift standard. Will a 70's or later 3spd work with my factory bracketry? If not does anyone know the mods necessary to swap to a standard that will fit behind a windsor engine and work with the three on the tree shifter?
Transmission
I did it a long time ago and It worked with a 289. Although I don't remember the pedal linkage that connects to the side of the engine block lining up just right. Let me know if you heard something else.
Truckfarmer2
