Rallycross. We don't have that here, which is probably a good thing for my car budget.
You're trying to do something similar to what I'm doing with my truck (and sort of the reason I bought it so many years ago). I have not driven a pre-65, but can give some impressions based on owning a 65-66 style truck (Twin I Beam, FE V-8).
To me, disc brakes are a must, particularly where you live with the kind of hills you may need to deal with. Not only for stopping effectiveness, but to manage heat which drums do not do very well. The Twin I trucks are easily swapped to discs with factory parts; the early trucks require purchase of at least some sort of minimal 'kit' which will be spendy.
My FE is rated at 208 hp according to the air cleaner decal and it's adequate but not inspiring for power. I think the Y block will struggle. You may actually be better off with a six swapped to a 300. While I could probably tolerate a Y block here, in CO it's going to be a struggle with the altitude I'm guessing. The FE cooling system (with new stock radiator) does just fine. Can't comment on the Y's cooling abilitites.
The truck handles the weight just fine provided you place the car on the trailer properly. Trailer brakes are a MUST. Power steering sure would make parking a lot easier but I don't like the numb feel it gives (the racer in me) so I struggle with Armstrong steering, which really only sucks when backing it into my driveway at home.
These trucks were used for work when new, so are perfectly capable of handling such a task. The only problem is what we expect from them on a modern level. Newer trucks have superior steering, brakes, suspension, power, etc which makes life more pleasant. But, I'll put up with some of the shortcomings and take extra time for my trips to enjoy the coolness that is an old truck.
If I were you, I would go for a 65-66 truck which would enable the easier brake swap. As an added bonus, the cab is even larger. An F250 will get you heavier everything (brakes, suspension) but will have a non-fuel-friendly rear axle with a low top speed. The 4 speed is the way to go for towing, IMO, as you get the granny 1st gear and don't have the balky column shifter to worry about.
