welding
ezernut9mm
Sweden
welding
Post by ezernut9mm »
i'm beginning to think it's not my forte.
put a piece of steel on a flat surface and i can weld to it. but this upside down, cheap a@@ imported cab mount crap is driving me insane! all i am able to do is blow through the replacement panels and maybe get a quarter of my seam to stick.
i cannot turn the welder down any more either. it's at it's lowest setting.
i am half tempted to part this thing out and go buy that 63 uni. at least then i would be able to drive the thing once in a while.
i think my neighbors are starting to get pissed at my mess in the driveway too. it's only a matter of time before i get a citation for inoperable vehicle.
i need to take a break. end rant/
Max
Post by Max »
Chris, it's most likely the machine buddy - don't be so hard on yourself. But definitely practice on scrap first to get the feel. If you have it turned down and you're still burning through 16 or 18 ga sheetmetal, then don't booger up the good pieces trying.
Most sheetmetal welding is similar to spot welding anyway. It will warp considerably if you try running a bead all the way down an edge - even if you have a low amp and wire speed. Just a zap here and there until you have everything stitched.
Good stuff here too: http://weldingweb.com/
ezernut9mm
Sweden
i don't know what gauge the replacement panels are, but they are only about 2/3 as thick as the original metal. i am not burning holes in the original stuff, just the cheap replacement pieces. plus i am in a really hard to work on area. under the truck on the cab mount. i think i will flip the cab up on it's back so everything is right side up and easy to reach. i just need to step back a little.
thanks for the link max.
don morris II
Post by don morris II »
a stitch in time saves 9 points on the insanity meter :D
FORD, FAST, FLYING, FIRST, ALL START WITH F IS,NT THAT "SLICK"
Anthony
Post by Anthony »
I feel you man...
[albumimg]4882[/albumimg]
Anthony
ezernut9mm
Sweden
anthony, how heavy is the cab? how much beer will i have to buy to get some friends over to help me tip it? lol
About 2 guys and a six pack to tip the cab buddy.
Have you tried drilling some holes at the overlap and rosette welding it? This will concentrate the heat on the original metal and where you get into the thin stuff the original will be there to back it up. They will work like spot welds.
a couple things
overhead welding is the most difficult especially if you have not done a lot of welding and not many even want to do it.
the material is very thin which requires a lower heat than the machine can provide, hence the need for the spot or rosette as Greg posted.
only takes 1 person to tip or remove a cab as that is all there ever is here, me. must be very inventive in how i do things sometimes.
its a lot lighter without the doors and seat.
66fordtrucknut
Post by 66fordtrucknut »
Play with the wire speed too, Definitely play with some scrap. What size wire are you running? I like using .023 for bodywork. Are you using Argon/co2 or straight co2. Like greg said the plug welds are the way to go. If your stuck with a butt weld try and get where your welding vertical down, if you have a big gap you can use a backing plate of either alum or copper it'll kinda act like a heatsink, the trick is how to hold the backing plate. Which depending on what your doing or even if you can get to the back of it. Keep practicing, don't be in a hurry, you'll be a pro before you know it.
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
Charlie, he is using my old stick welder with a Stitch welding electrode holder. I have used it on 18 gauge with no issues. Kinda makes worry about the structural integrity of the patch panels - they do have endure the roads after they are in place.
Chris, try cutting some 16 gauge into 2" wide strips, drill some 1/4" holes in the patch panel, clamp it to on piece to make a flange, then drill for rosettes again using rivets to clamp it in place, then weld in the rosettes. After you get it solid run a bead where the 2 panels butt, your welded on flange will be behind it giving you some materiel to work with, you may even be able to step up to 3/32 rod for that. This is what I would do in your shoes with that thin metal.
jwh f-100
Post by jwh f-100 »
Greg D wrote:About 2 guys and a six pack to tip the cab buddy.
I agree to try that. Thats kinda what I do. Drill the top and just enough of the bottom layer to clean it..
A guy taught me a trick for welding lighter stuff with a stick. When you get the "spark" started have an extra stick in your other hand to add more material.. Worked quite well..
Jason
Beer will change the world.
I don't know how but it will.
66fordtrucknut
Oops, I thought he was mig welding. Stick welding that thin of metal will require a bit more practice and patience. Sounds like Greg has you going down the right course.
Charlie
62' SWB uni 223
Anthony's floorboard
I had been kicking around ideas on how I was going to fix my cab mounts and floorboards on the 63. After seeing what Anthony did, I am going to do the same thing. Much easier than having to pull the cab off the frame, and can clean and paint the bottom of the cab, too. TR
ezernut9mm
Sweden
i am still standing back and taking deep breaths. but i did get the cab flipped up on end. if it would stop raining every time i plugged in an extension cord i might get started again.
Not much better up here. That should help some. One other thing, you let it get to you and it will only get worse. Welding thin stuff is best done relaxed.
ezernut9mm
Sweden
i did some cleaning off of the paint and bending on the cab corner to get the contours better tonight and i will try and do some zapping tomorrow evening if it is nice out when i get home.
