Shop tools explained
Uncle Skip
Post by Uncle Skip »
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it. Great for making bloody knuckles.
WIRE WHEEL/ BENCH GRINDER:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh --'
SKILL SAW:
A portable cutting tool used to make studs and other wood projects too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. Also handy for converting wood products to sawdust, quickly.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to finish completely finish rounding off bolt heads. And, if nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
AKA, fire wrench. Used almost entirely for setting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the wheel hub where you wanted to remove a bearing race..
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles at high speed for testing wall integrity.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and poking holes your palms.
PRY BAR:
A very handy tool used to crumple the metal surrounding any clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
Another very handy specialty tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit, or to flatten your thumb/ finger causing you to loose a fingernail.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while they are in use.
Son of a b*tch TOOL:
Any handy tool that you grab and throw across the garage while yelling 'Son of a b*tch' at the top of your lungs after a judicial application of the hammer to said finger or thumb. It is also, most often, the next tool that you will need.
U@ss
:laughing: :rotflmao:
DCarr
Post by DCarr »
:lol: :laughing: X2-Thanks,Skip.
johnzmu
Post by johnzmu »
I thought I was the only one!
ABA
Post by ABA »
Hey I used some SOB tools yesterday while removing the heater core from my T-Bird....then a threw that MF'n heater core across the yard.
Engineers should have to work on things they design before they get their degree. Replacing a heater core should NOT be a 10 hour job. bang.gif
'01 F150 Lightning
490RWHP
Gas Mileage? What's that?
Jerry
Post by Gritsngumbo »
Great Skip: That should be a "sticky" in the projects and builds section.
64 f100
Post by 64 f100 »
Skip, after looking through your deffinitions, most are right on, with one exception, pliers. These are also called a poor mans ratchet, commonly used by PO's for rounding off every bolt they can get to, or stripping most of the threads off any studd leaving threads only on the end past where the nut is. This of course means you can't tighten the nut nor remove it.
You left out drills as equipment to test every drill bit you have of the right size, to see if it will cut anything.
Vice grips are also the tool you use to hold 2 pieces of metal together permanently, as you weld all three together.
Drill bits are any of a number of dull line up tools, only sharp the first time used.
The gawdamit is the tool just out of reach you need, when you have one shoe off, and holding something in place with your toes and one hand while doing a balancing act on one leg.
Favorite tool , the one you've had since birth, old faithfull, your right hand, worn out, but can't throw away. Lives in your tool box to never be thrown away, and can't be replaced. Example, my very short 9/16 SK and Wayne 6 point socket, that I can't find anywhere.
65f100_Thug
Post by 65f100_Thug »
vice grips also make a good slick door handle after your kids jerk the door handles off the inside of your slick. I think its funny how all people think because its a old truck they automatically have to jerk the door handles to get them to open and slam them to get them to shut.
HAVE YOU DISASSEMBLED A FORD LATELY?
10136 98349929981298119816
