help
help
I'm sure this has been covered on this forum many times but I couldn't find anything using the search.Been tryin' for over an hour to post pics of one of my trucks, but my computer illiterate a#$ just cant figure it out.
- Falcon Interceptor
you have to have them uploaded somewhere. If it's in the albums, I believe you have to open each link.
right click and "copy image location" you would then paste it into your message. Highlight what you posted and push the Img button.
You can also push the Img before and after you paste it but it will got to the bottom of the message.
Also try this
[albumimg]picture number[/albumimg] -must have the /
It will show up as a thumbnail link to it in your album
the number is where it says "ID: 1234" under the pic in your album
Hope that helps
Also try this
Hope that helps
Last edited by Falcon Interceptor on September 19, 2009, 6:53 pm, edited 2 times in total.
Anthony
John, if you will go to your album and click on the blue highlighted area beside the word "Image" It will bring up a smaller image. scroll down under the pic and highlight the "BBCode" and copy. Go back to your post and right click and hit paste. this will put up a small pic that is clickable to a bigger pic but not a huge pic in your post... Hope this helps, Anthony
[albumimg]6479[/albumimg] [albumimg]6478[/albumimg]
try it out...
try it out...
- Johnny Canuck
John I dunno how you did that but it almost works better than this
when you go into your pic underneath it it says
[albumimg] 6478 [/albumimg]
so you go across it and highlight it by holding the left mouse button down and dragging across it. Once it is highlighted, you type in "ctrl C", both keys at the same time. This is a microsoft "copy" command
then you go in to the text of the post you are typing and press "ctrl V" both keys at the same time, this is a microsoft "Paste" command
then you have cutting and pasting down
- dotcentral
Not the image, the location.dotcentral wrote:This is the process to add photos from a slick 60's album? Doesn't work for me. JC, highlight the image, copy & paste?
If I use the right mouse button on the pic it gives options, such as copying things-you want image location
Or the BBCode. If you were to click on the "Image: name" under the pic, it will then have a bbcode under it. Don't click the picture. Copy and paste that
Should look like [albumimg] 6481 [/albumimg] You can use that same format if you know the ID number.
It's so complicated
