Is re-chroming parts actually THAT expensive? I stopped by Huntington plating and showed him my door handles and CC backing plates and he wanted $175 apeice to re-chrome them. This sounded high to me but maybe I'm wrong. Any input on chrom pricing around you all? I don't mind to put them on as is but I would eventually like to have them redone. new ones are cheaper than re-chroming on his $ scale.
It does sound high. You can buy new outers for 220 a set and handles for 40 each. 260 total better than 350.
A lot of shops charge high for single work if you had multiple pieces and talked with them they may come down or find a shop that is more reasonable. Usually they only chrge high if there is a lot of repair and prep work needed but handles usually only need stripping and replating no repair like bumpers and trim parts.
Call around....
I'm with you, I just put my old ones back on until I can scrape up the extra cash for some new gold teeth. Around here that's about the going rate. No small mystery why I've painted everything...so far. The Harley guys will tell ya chrome don't get ya home!
BTW orange & white truck is lookin great! One of my favorite color schemes.
You have to consider what chroming is here too. The dipping isn't the expensive part - it's the by hand polishing in between the 3 plating steps (polish, copper, polish, nickle, polish, chrome) - with Re chroming it has to be stripped first - add another step. Almost never worth it for a reproduced part - best saved for when a used part has to be resurrected.
Most everything for our trucks is less expensive as repro. The door handles are certainly one of them. The only exceptions I've found are the bumpers...the repro pieces just aren't as good.
I got some repro mirrors from LMC- They used Metric mounting bolts, and the heads dont have enough range of swivel, the passenger side mirror is nearly useless.
I was yanked a while back, I bought some hood hinges from Dennis Carpenter a few years ago now, and finally got around to installing them, turns out the bottom mounting hole, with welded nut is an oddball metric or something. Never did find the right bolt, ACE had no idea what it was. I had to drill out the nut and weld a real nut to the back of it.
The slotted holes didnt line up either, I had to cut them Extra long with a dremel to align the hood.
You just cant get good stuff anymore it seems
Not really fair to say "it's all crap". Since our discussion was on chrome items, I haven't found anything other than the bumpers that's been a problem. Most of it's made from the same tooling as original. I got mirrors from Bob Drake and they fit perfectly.
