I have a new friend that is having a terrible time with a Chevy Citation.... Her Jetta got massacred by the flood in Sedona, and has to drive this POS until the insurance comes thru, which will probably be a while.
The thing has some sort of intermittent problem where it dies when you put it into drive, so she has found the only way to get past it sometimes is to rev it up in reverse and drop it into drive with a case of whiplash and (jettison muffler and lodge in rear wheel!!! LOL)
any ideas what could cause this POS to crap out in drive, but not Reverse?
This is perplexing the sh!t out of me. My mom's camaro's bad ignition switch comes to mind which haunted my dad for about 8 years, car would be going down the road and just momentarily turn off. Then pop back on within a few seconds and try to blow off the muffler. Then it would "go away for a while".... etc. The switch turned out to be worn out, no click left in it at all. (the thing on the base of steering column with long stupid linkage)
but I don't think this is that pretty positively. And I really want to come up with a fix!
oh yeah, and today the right front brake locked up and was smoking... lol I think I may be visiting That cute little thing too..... LOL
1980 Chevy Citation of all things
blackagatha
- DV65CustomCab
Bad motor mount(s)? If the engine rocks it may be tugging on a wire or cable somewhere. They can cause a lot of problems like that.
Hopefully it doesn't have the 2.8. They were known for intake gasket failures and would mix coolant into the oil.
Stop The Longbed Hate!
Now: '93 F150 Lightning
I seem to remember the top front "dogbone" engine mount on these being a problem when I worked at GM dealerships back then. Could kinda fit with Dwight's suggestion.
- Roger Carter
- dotcentral
Try this place. http://www.batauto.com/Forums/index.php
They are pretty good for "late model" stuff.
blackagatha
If it Was due to bad motor mounts, I would think that driving it easy would be ok, and do bad things when you drop it in gear like that.
It doesnt make sense that slamming it into gear would make it work if it's a pinched wire or something.
Now the torque converter issue, that sounds a little more convincing to the point, MAYBE.
Seems like if it was staying locked up, it wouldn't function in reverse either, but she has NO problems with it in reverse...
Maybe the trans is geared lower in reverse so it's having less adverse effect.
blackagatha
- Total Gearhead
Roll it down a hill and drop it in drive. if it runs and drives see if it stays running when you stop. If not its the lock up.
aka "Horsepower"
61 F100 Step
"One Step Closer to the Edge!"
http://www.hubgarage.com/mygarage/TotalGearhead
http://www.myspace.com/totalgearhead
dub@thetotalgearhead.com
http://www.facebook.com/group.php?gid=214833125322
If it has a motor or wheels I'm in!
61 F100 Step
blackagatha
I need to ask her, I havent seen the car yet. Considering she has to rev it as high as she can in reverse???? and then drop it in to drive and make a burnout to get rolling, I think so.
And complicating the problem is that everybody she knows is throwing their solution at her. She doesnt have the slightest idea what any of it means, and cant sift thru it all. I dont know if she's believing anything I'm saying because her dad's having other screwy ideas!
For the locked up brake caliper, they seem insistent that its the Master Cylinder.... UH NO! that would make all the brakes drag if it were to do such a thing. In my experience, MCs just go flat...
I think she just has a dirty caliper, mostly, that wont move freely. Maybe a collapsed hose to it.
.....I just hope she'll let me take a look at it before she pays some dumbnut mechanic $500 to fix a $50 job
- Total Gearhead
sounds like a caliper gone bad
aka "Horsepower"
61 F100 Step
61 F100 Step
