help -- where is the frame VIN number on my 61 uni?
richabilly
the door plate was removed and replaced before i bought it. It needs the DMV inspection and they said they cant find the vin on the frame where they are looking and told me to find it and come back.
where should it be on my 61 f100 uni?
Thanks so much!
Thanks so much!
1961 shouldn't have a door plate - it should be on the inside of the glove box door.
I believe it should be on the drivers side frame rail close to the core support.
Welcome to Slick 60s.
richabilly
the vin is stamped into the passenger frame rail 2x, one is near the shock tower, the other is under the cab about where the passengers feet are.
http://fordtruk.com/forums/viewtopic.php?t=11525
richabilly
richabilly
Yes the front - I just had the side wrong (CRS).richabilly wrote:oh and i assume the front shock tower? im sorry if that was obvious -- i just am new to these trucks.
richabilly
- unibody madness
... passenger side, near tower,on the top,...star on each side..., where it can fill up with all kinds of crud,making it near impossible to find.
best way to find it is with some 100 grit wet or dry sandpaper and a wire wheel
Last edited by unibody madness on November 16, 2009, 7:43 pm, edited 1 time in total.
richabilly
If you reach down beside the engine on the passenger side with a piece of 100 grit sandpaper on a block and sand the top of the frame rail you should be able to get it to show up.
richabilly
thank you all for your posts. i did finally find it -- right where you said it was going to be. I found the one in the engine compartment -- after much engine degreasder, elbow grease and a wire bruch, there it is. And it matches the title and the door plate.
im off to the dmv to get it registered tomorrow!!!
- Gary Seymour
