brake lights are out.... help
richabilly
Post by richabilly »
searched for this but didnt find anything. A friend noticed my brake lights are out. Running lights work, turn signals work, hazzards work, but no brake lights.
at first i thought fuse -- but all the other things work and i didnt think the brake lights would have their own fuse. Besides, i have NO clue where the fuses are on my 61 uni -- anyone help on that one?
My second guess is the brake pressure switch on the master cylinder. does that sound likely? Or do you think it is something else. I am a novice wrench, but this seems like something i can handle and i want to work on my own truck as much as possible anyway.
Thank you!
Obsa
Post by Obsa »
Since the pressure switch just completes the circuit for the brakes you can check it by removing the wires from the switch and use a jumper to connect them if the brake lights come on then you have a bad pressure switch.
Obsa wrote:Since the pressure switch just completes the circuit for the brakes you can check it by removing the wires from the switch and use a jumper to connect them if the brake lights come on then you have a bad pressure switch.
key must be in on position for this test to work
the fuses for 61 are on the bottom of the headlight switch
Obsa
Post by Obsa »
Thanks Ice, I forgot that detail that darn CRS again
Ford blue blood
Post by Ford blue blood »
The brake light circuit should have power all the time. There is a 15 amp fuse that powers the parking lights, plate light and the brake circuit. Check your park lights and jumper the brake switch if there are park lights (fuse is good).
Many great Fords,
the early trucks had to have the key on to make the brake lights work. not sure when that changed.
none of mine work without the key being on.
blackagatha
Post by blackagatha »
ICEMAN6166 wrote:the early trucks had to have the key on to make the brake lights work. not sure when that changed.
That's strange.... Personally, I would re-wire that so they will work any time...
Casey 65
Post by Casey 65 »
my '65 has two terminals on the master cylinder that have to be cleaned with steel wool every so often.
Ford blue blood
Mine is a 61 and bone stock. The 48 I had was just a bare cab when it came home so don't know about it. The 73 brakes were hot all the time and the 93 brakes are hot all the time.
Many great Fords,
rayford
Post by rayford »
i had the same thing happen on my 65 it was a bad blinker switch
Post by Gritsngumbo »
FYI: Here's a pic of the fuse box/headlight switch assembly.
I printed out a copy and put one in each glove box for reference.
