Guage clusters
HOOK&GO
Guage clusters
Post by HOOK&GO »
Hey I have the custom cab 66 f100 with the horizontal speedometer and would like to add a couple of guages and a small tach but do not want to clutter up or hack the dash. I was thinking oil pressure water temp and a tach to keep tabs on things. I am considering a below the dash mount but those never look right. Any suggestions?
BarnieTrk
Post by BarnieTrk »
If you look around in some of the gallery pictures, you'll see that FoMoCo offered / installed an optional Amp gage and an Oil pressure gage to either side of the sweep speedo cluster. So if you want to keep it looking OEM, you may want to hunt up a pair of those gages and install them. A complete cluster might be easier & less expensive though......
On my F100, I have a old SUN tach which I am happy with it mounted on the steering column. I mounted a trio of gages below the dash, under where the radio would be - to be kinda out of the way, but still readable without any problems. I don't think it looks bad, and it works for me!
BarnieTrk :popcorn:
HOOK&GO
Post by HOOK&GO »
yeah I think that should work there was a really large tach on the column before 10K RPM and huge shift lite lol I just want a smaller one to keep tabs on things and I see the space you are talking about outside of the cluster to the left and right. Maybe some vintage looking guages might fit in there with the rest of it.
Casey 65
Post by Casey 65 »
this one was made from a dash out of my parts truck
Casey 65
Post by Casey 65 »
Here's the other view.
what do you think of the new dash & gauges?
jkimbrel65
Post by jkimbrel65 »
Nice work Gerry.Looks sweet!! :thumright:
I tried being normal once...
36truck
Post by 36truck »
Very nice Gerry. I've been thinking about gauges for my dash also. The tach is the hardest one to make room for. Most likely will go custom to make it all look right.
Tom Williams
65 CREW
Post by 65 CREW »
Casey 65 wrote:this one was made from a dash out of my parts truck
Is that panel under the dash made from a another dash. I have been thinking of doing something similar.
1965 Ford F350 Crewcab, currently getting a Cummins 6bt conversion.
Casey 65
Post by Casey 65 »
Yes, bottom part of the dash. It's shorter in the left side to avoid interference with the parking brake.
texasyeti
Post by texasyeti »
Very slick!
blackagatha
Post by blackagatha »
the panel looks like something in a ritzy hotel... lol
you NEED a matching new set of knobs for it.... DENNIS CARPENTER, BABY! they look lots better than the others available..... They don't turn yellow...
Casey 65
Post by Casey 65 »
I'm planning on replacing the yellowed inserts on the knobs with the same pickguard material behind the gages. Also, installing the pickguard material on the lower panel that I made and chrome tape on the stock switch planel to match the machined look of the original panel.
