2.
3.
Direction?
Not sure how to go about cleaning and what fluid to add etc.
X2Obsa wrote:What I would recommend is to change over to a dual chamber Master cylinder. We have changed using this master cylinder:
That is the one we have used twice on drum/drum brakes on both the 66 (which now has been changed to PDB) and on the 63.Gritsngumbo wrote:X2Obsa wrote:What I would recommend is to change over to a dual chamber Master cylinder. We have changed using this master cylinder:
Obsa: Is that MC you listed for disc/drums? or for drum/drums?
Hey Greg, why the different master cylinder on the 65-66? We used the 68 mustang MC on both the 66 and the 63. I am sure that either one will workGreg D wrote:When you get your dual Master; if it's a 65-66 get one from a 70 F 100 - if it's a 61-64 get one for a 68 Mustang. There are some pics of the one in my 62 in here if they help you.
http://fordtruk.com/forums/viewtopic.php?t=2647
ICEMAN6166 wrote:while i agree with changing that out for the dual mc, disc brakes are a personal choice. i keep all my drum brake systems maintained properly and have had no issues with stopping.
the mc conversion is very simple and easy to do.
i would suggest you start with the mc conversion , and make sure your shoes, wheel cylinders and drums are in good condition, then later if you desire you can change to discs.
Skip: That is good information to know. I had intended to PM you and ask that question, but hadn't gotten it done yet. I would like to have new lines, but didn't want to have to hack into the new "original" lines for the dual MC.Uncle Skip wrote:Call Inline Tube or check their website.
They have custom bent lines for your truck, and will make special lines in case you have converted to a dual master cylinder and or disk brakes.
U@ss
The tubing benders are relatively cheap the real costs is a flaring tool that works on stainless and makes the double flare!Greg D wrote:I am guessing a good tubing bender is a bit cheaper. You will also have it if you need it again.
