I got this from FordboyPete and added a couple of things.
To wit.....
This group is numbers among the very few people I know who can understand the phenomenon covered in Joseph Lucas's Treatise on the movement of electrons in an electrical system, which I have attached for your perusal.
It's absolute genius and I can testify to its validity, after having had personal and intimate associations with various and sundry British vehicular products thru the years.
To bad Lucas didn't expand his research into the French methodology of automotive wiring.
That would have been even more interesting.
I think theirs has something to do with yellow mustard.
Thanks Pete.
Uncle Skip
A Treatise on the relevance of smoke to electron movement by Joseph Lucas 1842-1903.
All electrical components and circuitry depend on proper design and maintenance in order to function correctly. Correct function is the transmission, application and use of electrons for powering certain devices. Transmission of these charged ions through visible spectral manifestation of their migration, otherwise known colloquially as “smoke”, is possible. It is smoke that makes these electrical things work. Smoke is the key to functional supply and circuitry and the key to all things electrical.
We know this to be true fact because every time the smoke is allowed to evacuate a circuit it ceases to function correctly, and stops working accordingly. This event can be replicated with the same net end result each time through and with empirical testing. For example a large copper bar laid across the terminals of a fully charged Automotive battery produces prodigious, copious, quantities, of foul and acrid smoke after which a battery is virtually useless, or in common terms, dead. In addition if one observes clear evidence smoke escaping from a GM starter motor or starter solenoid, or worse Lucas Dynamo, Voltage Regulating device or Zeener Diode, further observation will determine the device no longer functions and is useless therefore requiring replacement.
Logic behind this is elemental and inescapable. Function of circuitry and wiring harnesses is to conduct or transfer smoke between, to or from devices or components in a system. When conducting systems, their devices, or components spring a leak then smoke escapes from that system and nothing works correctly afterward. Starter motors on British Automobiles or Motorcycles were so problematic, so known for emitting or releasing large quantities of smoke early on, so they were simply left off. Vehicles started mechanically were kicked thru or cranked for years after that. It is reported that Lucas electrical components were most likely more prone to electrical leakage than Bosch, Nippondenso, NGK, or various American counterparts. Experts point out that Lucas is British in origin, all British things Leak more smoke than others.
British engines leak oil, shock absorbers, hydraulic forks, power steering gears or pumps, gear cases and automatic transmissions all leak fluids mercilessly, and British Intelligence leaks national defense secrets. Therefore it follows all the British electrical systems will leak smoke. It is only natural and normal to have them do so, and do so well. Once again logic and reality of this is clear and inescapable. The British used Lucas Refrigerators for years. That in fact is why Brit Beer is served room temperature to this day.
Sometimes the technician may miss the erring component, which released smoke and rendered a system inoperative and useless. Rather than using an approved VOM, try the sniffing method. If you sniff around enough you can generally identify a suspect component by its’ telltale, unmistakable acrid, odor, identifiable as that of smoke. Another phenomenon that directs ones attention to a developing leak is a brilliant flash of high voltage arc just before smoke escapes. Non Loss of system smoke is imperative for sustained usage.
In conclusion, the phenomenon of electrical current flow is easily understood as its’ mysteries fade away through the realization of the purpose and facilitation of it’s movement is in the smoke, and that’s how it all works, reliable or otherwise. It also explains why some components actually fail while in use.
Remember the words of our founder, Joseph Lucas: “ Gentlemen should not motor about after dark anyway ”.
Wiring theory
- Uncle Skip
Wiring theory
Brian Taylor
- Roger Carter
Skip,
As a construction electrician with over 40 years in the industry, I have to applaud Mr. Lucas, and you, for such a complete and easy to understand description of electrical theory.
I can personally attest to the fact that if you can smell smoke, things is bad. And if you can't see because of the smoke, things is really bad.
Somewhere in my treasures I have a fuse chart that should accompany Mr. Lucas' treatise. I will post it when I locate it.
Again, thank you.
Roger Carter
Again, thank you.
Roger Carter
fmartin_gila
I also have an ad for replacement smoke for the Lucas systems. Finally found it. Go to http://www.bctriumphregistry.com/smoke.htm
Fred
Fred
fmartin_gila
- Uncle Skip
