I just found out the hard way that LED units intended for computer use need re-inforcement of the wires.
The solution is what is called, in the aircraft industry, "potting".
You seal up the wires with almost anything including silicone sealant.
But because the unit here was so small, I used 2 part 30 minute epoxy because it would flow into the tape barrier I made and not get so messy.
Take a look.
I strongly suggest that you do this to any LED you plan to use so the wires don't pull out of the fixture.
Happy New Year.
U@ss
Tape the base with masking tape. Epoxy won't stick to the tape. The vise grips hold the light in a vertical position so the epoxy will settle level.
[albumimg]7336[/albumimg]
Peel off the tape and you have a potted light, where the wires won't pull out.
This is what it looks like finished.
[albumimg]7337[/albumimg]
More on LED's
- Uncle Skip
More on LED's
