Weight of a C6
36truck
Weight of a C6
Post by 36truck »
Does any one have documented weight of a C6? I got the freight bill that was way over priced for the weight of a C6. Need some documented weight.
Tom Williams
dotcentral
Post by dotcentral »
I found this online, it claims 203 lbs, but I have a hard time believing that. http://www.motorcraft.com/FordPowerProd ... v10-04.pdf
Edit to say, I found this latter.
Fourth paragraph.... http://www.fordmuscle.com/archives/2005 ... /index.php
I have picked up and carried C4's and AOD's. AOD's are heavy mothers. I have moved small block C6, sliding it across the ground or floor, and I would have thought it weighed less than an AOD. Guess I never picked the thing up because I would have remembered that back ache.
36truck
Post by 36truck »
I would think that includes the torque converter. What's a converter weight?
Tom Williams
they are fairly heavy with a full converter. i dont think its 203 lbs though.
a big cast iron clark 5 speed is only 186 lbs... t-98 is 124
:shock:I don't think that's right!, I just had mine service before putting it in and I lifted it in and out of my transit van on my own, I reckon about 70kg`s say 150lb
