Heater fan/blower motor???
36truck
Post by 36truck »
On my 03 Crown Vic the heater fan only works on the highest setting not on any lower ones. Ideas
Tom Williams
Brian Taylor
Post by Brian Taylor »
Not sure of the wiring on that but normally when it only works on high the switch has a resistor which make the motor run at resisted speeds, low medium etc, It is usually just the switch. It is easier to get to and easy to replace.
1966 Ford F-100 LWB 300
fire truck
Post by fire truck »
Yep, bad resistor... some are a pain to get to. They cost anywhere from 35-100 bucks....
