Question for you F100 Gurus. Please Help!!
lane
Post by lane »
I'm new to restoring pickups and so far I'm digging it. I've got a 66 F100 that's very clean, but I have a cab that is completely rusted. I've found a cab on a 1 ton chassis that looks pretty close to mine with the exception of a "step" area on the floor - my current cab has no "step" built in. The guy swears that it's a 66, but I have my doubts. He also has a 62 that has the same inside step. My question is: If I buy this new cab with the step in it, will it bolt up to the frame the same way that my current cab bolts up? In other words, are the cab mounts, fender bolts, etc. in the same location to switch it up. This other cab is really clean with no rust, so I'd love to use it if possible. Any help would be greatly appreciated.
Lane
banjopicker66
Post by banjopicker66 »
No go. The F-350 and higher kept the earlier cab style, similar to the '64.
Look at how the steering column goes through the floor, and how it hangs from the lower dash.
Compare the front cab mounts as well.
lane
Post by lane »
Thanks for your reply. That's a stinker! I'm in Wisconsin and it seems like I've found about 4 cabs that all have the earlier style cabs that are nearly rust-free, but can't seem to find anything like mine that's in decent shape. Can you speculate on how much fabrication would have to be done in order to use the earlier cab and clip? Is the frame the same width?
Lane
A happy life is a simple life.
lane
Post by lane »
BTW: my truck has been modified a bit. It's has a mid-70's steering column and power steering unit installed (done prior to my purchasing it) as well as a 351 V8. I have a ton of questions for the man who had it before me, but he passed away, so I'm searching. This site has been extremely helpful. I'd like to shake the hand of the guy who started it!!
Lane
ezernut9mm
Sweden
Post by ezernut9mm »
another member here "hook&go" was looking at this: http://kansascity.craigslist.org/cto/1578825202.html
for the frame and front sheet metal. maybe you guys could work something out. i'll bet the slick60's express could help get the cab up there to you.
just a thought.
factorystock
Post by factorystock »
The 6o's was an interesting time for pickups, both Chevy and Ford made major mechanical changes to the pickups while the sheet metal looked very similar. The only cab that is a direct match is the 65 and 66 F100 and F250 2 wheel drive. Other 61 thru 66 cabs look similar, but they have major differences and will require alot of extra work to modify.
ezernut9mm
Sweden
i know. when i first got into these trucks i figured they were all the same. didn't take long to start figuring it out though. lol
the bumpsides are that way too.
lane
Post by lane »
Sounds like I'm back to the drawing board. I'll see if I can get ahold of "hook&go" and maybe I can share a truck with him (assuming it's a him). :) Thanks for your help.
Lane
64 f100
Post by 64 f100 »
One of our members ahd a cab on Ebay a week or two abgo that did not sell. His opening bid was only 500 for it and the frame. Nice cab , but was in someplace like Nevada. I have a fairly nice 65 cab here in southern Illinois for about the same price.
lane
Post by lane »
Thanks Rich. Do you have pictures of the cab you could send? How's the rust? They use so much salt here in Wisconsin that it's a huge issue.
Lane
608.385.2889
lane
Post by lane »
ezernut9mm,
I'm new here, so what is this "Slick 60's Express" you speak of? I'll do some looking.
Uncle Skip
Post by Uncle Skip »
Lane.
First, welcome to the family.
Now tell us how far you want to go with your truck?
I'd suggest that you take it to the frame and start ground up.
Trust me, its cheaper if you do it right the first time, both in money and in time committed.
I have several supporting reasons for this opinion.
1. Mechanically, the truck is 40+ year old and everything needs attention; brakes, bearings bushings, engine choices, core support, wiring and on and on.
Brakes need to be replaced hub to hub.
DO NOT skimp on this system.
2. When you pull the cab off, you can take a very close look at it and choose what you can save and what to take to the recycle yard.
Keep all the little parts: screws, clips, nuts, and hinges
Window vents and parts, e-brake parts, switches, and on and on.
3. With the old cab gone, you clear up a lot of space for other projects on the truck, including working on the brakes, cleaning the frame, etc.
4. You can learn the hobby with a lot of help from here and not overload your schedule with to many competing projects all at once. And if you find out you need special tools, you can buy them or borrow them as the need arises.
5. And probably most important, you give yourself time to look for a good cab for a good price and not rush out and buy something you probably shouldn't have bought.
Anyway, that's my take on your new project.
Good luck and let us know when you need help.
Uncle Skip
lane
Post by lane »
Uncle Skip,
This is a GREAT SITE and thanks for your helpful advice. I've done several frame up restores in the past. This is my 9th project. Here's what I've done so far:
1. Replaced motor with rebuilt 351m (not my best choice for engines, but I'm currently using it as a daily driver and it had a 351m in it with absolutely no compression). It was just cheaper to replace with a like motor.
2. Dropped in a 9 inch rear end, new suspension/shocks.
3. Had a new drive shaft made for it. It's still nice and shiny.
4. I'm just finishing up the gauge cluster and will be dropping in new wiring harnesses. Harnesses will wait til later.
Right now it drives and performs great, but looks a little ugly. I have another car I can drive in the summer, so when school is over (I teach at a college), I'll be pulling the body off of the frame and continuing working from ground up. I'm trying to get all my parts and pieces together by mid-March so I can hit it hard for my 4 months off. I'm extremely excited to get to work on this and see an end result. My job gives me a ton of free time and I'm single (and plan on staying that way until the truck is done - otherwise it'll never get done) :).
Lane
Johnny Canuck
Post by Johnny Canuck »
Welcome to the club. The slick 60's express is simply a bunch of guys who happen to be going from point a to point B and will take your stuff with them. Then the next guy takes it from point c to point d. etc. Not overnight delivery, but effective, especially when you are shipping big stuff (like a cab).
Heed what uncle Skip says about keeping all the clips , little springs, vent window parts etc... that stuff is not repro-ed or made any more.
The story is, they switched the frames of these trucks starting in 1965 from an older design from the 50's, with a straight axle and a steering box fixed on the end of the steering column, to a more modern design with twin I beams and coil springs on the front.
That only happened for the lighter 2WD duty trucks, and made a lot of stuff interchangeable (on the newer design) with Ford trucks right up to the end of the seventies. The older trucks interchange down to the late 50's. The Slicks looked the same from 1964 to 1965 on the outside, but had huge changes in the frames and running gear.
Best of luck, twin I stuff is really not that hard to come by. They built more trucks in those 2 years (especially '66) than the others.
lane
Post by lane »
Thanks Johnny,
Maybe you can answer this next question then. Are the inner fenders from a 66 interchangeable with the early 70's inner fenders? They look like a similar shape and I've heard that they are, but want to make sure before I make a purchase. My knowledge so far is from cross referencing between different catalogs (Dennis Carpenter, LMC, F100 Central, etc.).
Lane
Johnny Canuck
To clue you in on body style terminology quickly, there are:
Fridges '57-60 (they look like a refrigerator)
Slicks '61-66 (they are slick)
Bumpsides '67-72 (they have a bump down the whole side, on this truck where the chrome runs)
Dentsides '73 -79 (they have dent down the whole side of the truck, roughly where the bumpsides had a bump
So to answer your question. The bumpsides have a different radiator support and are longer on the front end than a slick, so I doubt if a bump inner fender would work on a slick. I have heard tho that you can convert the dentside inner fenders, which were made of galvanized steel and didn't rust, to a bumpside one by removing a little bolt-on extension and switching the hinges to the inner rather than outer side of the fender.
The short answer to your question is No, not without fabrication.
lane
Post by lane »
Very helpful. Thanks. I've wondered about the terminology. I definitely like the look of the Slick!! Thanks.
Lane
