Where do I buy BED MOUNTS...... please HELP!!!
- Nick64Slick
bed mounts for a 64' Styleside..... I can't remember who sells them. I don't think LMC has them and I've been through their catalog and NPD, etc. a million times and can't find them. I even remember reading there were two different sets based on VIN in 64' but can't remember or find where I've seen that..... please HELP
thanks ahead of time, cheers!
-N
-N
fire truck
- Nick64Slick
- Nick64Slick
bump
c'mon gents and gals..... anyone???
William-in-St George
Bed Mounts?
Not sure what you are talking about? I cut some rubber washers/cushions that I put between the bed and frame to prevent squeaks and I have seen wood spacers in the same location, but I am not sure what "bed mounts" you are talking about.
William-in-St. George
- Uncle Skip
He's talking about the wooden spacer that goes in the floor channel between the bed and the frame on flair sides. (some of the style sides used them too.)
They keep the mounting bolts from crushing the floor and channel when you mount the bed.
I had several pairs made but they're all gone.
You can make your own if you have an old one to use as a pattern like I did.
U@ss
U@ss
- Nick64Slick
there are body mounts and there are bed mounts, I have the body mounts I need the bed mounts. they exist, I've seen them, just can't find them
I'm not interested in cutting rubber or going to lowes, no offense.... god knows I have plenty home made stuff, I just want to go factory replacement on these
in LMC or NPD they show them for the older trucks and the newer ones, but can't find 64-66 styleside....
not sure what else to say, hopefully someone can help
thanks
thanks
- Uncle Skip
- Uncle Skip
Bed blocks.
Wooden.
About 3.5" long and cut to fit inside the floor channel under the bed.
Measure the space and see how wide and how tall they need to be. Make them about 1/8-1/4" taller than they need to be.
The part that fits up in the channel has been radiused to conform to the curve of the channel. The flat part goes on the top of the frame rail.
They keep the bolts from crushing the floor channel.
You can make them no problem.
[albumimg]7731[/albumimg]
[albumimg]7730[/albumimg]
U@ss
Wooden.
U@ss
- ezernut9mm
NPD Catalog - http://www.npdlink.com/
1948-1979 Ford Trucks
Page 200
Part No. F-010875-3A Spacer Block, Bed Crossmember
Used inside the rails to support the bed.
F100 - F350, 1961 - 1972 - 6-1/2' Bed
$15.95/set
Page 200
$15.95/set
Hey Nick...sorry I didn't see this sooner. I bought mine from Bruce Horkey http://www.horkeyswoodandparts.com/page ... tingblocks
Hope this helps,
Hope this helps,
Doug
Riverside, CA
Riverside, CA
- Nick64Slick
- Nick64Slick
- stronger66ratfink
Nick, I'm not sure since I haven't ordered any. I just happened to be browsing through the NPD catalog and saw those. But I would check out Doug's suggestion - he looks like he has them and in a hardwood which is what they're supposed to be made out of. Not too expensive either. Doug's got a styleside truck too.
