PVC valve question
ClanCassidy
PVC valve question
Post by ClanCassidy »
Hi,
Just bought a new PVC valve (1970 302 engine). Should the internal poppet be loose ? When I turn the valve over, the poppet opens a little bit. I can push on it and it opens further. Seems like the poppet should have some positive spring force holding it closed in the free state. Then again, I never really looked at one of these things before so I don't know.
Does this part sound ok ?
Thanks.
John.
"Honest Honey, this should be the last thing I need to buy for the truck".
tomrooster
Post by tomrooster »
I beleive it should be loose ,So if you shook it , it would rattle. It shouldn't be positive spring force . Sounds OK. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
it supposed to rattle.
Hoofbeat Racer
Post by Hoofbeat Racer »
If it's clean, blow through the bottom but you won't be able to blow through the top :?
Mark
bobenhotep
Post by bobenhotep »
it is supposed to do that. use the highest flowing one you can get away with...
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
64 f100
Post by 64 f100 »
If it doesn't rattle, then you have a problem.
Johnny Canuck
Post by Johnny Canuck »
This brings up a question for me, as I seem to get pressure building up in my 351w's crankcase and blowing oil out.
The PCV valve, (brand new) is on the oil filler cap on the drivers side bank valve cover. It draws directly into the carb base. The return hose is from the air cleaner to the passenger's valve cover. When the engine is running you can HEAR the PCV buzzing, as it opens and closes in rapid succession.
Is this setup wrong? or why am I getting this crankcase pressure buildup, with a new and obviously functioning PCV?
Slick Fan
Post by Slick Fan »
Johnny Canuck wrote:This brings up a question for me, as I seem to get pressure building up in my 351w's crankcase and blowing oil out.
Is the engine a high mileage engine by chance? I had a 352 that did that & continually got worse. I decided the compression rings were worn out & weren't sealing very well any more. If I took the breather cap off with the engine running, I could actually feel air blowing against my hand, as I held my hand over the hole.
Also, sometimes a PCV can still rattle, but not flow as well as new any more.
Johnny Canuck
I had a head off it last year, as it blew a gasket. It's .030 over and doesn't even have much of a ridge on the top of the piston travel, you can barely catch a fingernail on it. I would say less than 10,000 miles since rebored.
So, I doubt that is the problem. 150-160 lbs compression. I think the PCV system may be hooked up backwards... just my guess. Not sure.
JC, try it without the return hose and see if it changes anything.
none of our trucks here have a return hose, and im not quite sure why you would need it?
