Probably not the appropriate place for this, but does anyone know if the 1985 model of steering column is interchangeable between the 2wd and 4wd models? It looks like it's almost a two piece column, but I didn't get to look at it that long. I have a column with a bad ignition switch and busted shifter that I need a replacement for. It looks like I could just replace the top half from a 2wd model. Mine is the 4wd model.
Thanks for any info.
Does anyone know about 80's model steering columns?
