Will they fit
62bandit
Will they fit
Post by 62bandit »
I found a good price on some wheels off a mustang, 5 lug summit pro stars w/ tires. i still have the stock front beam , and 9" rear end. Just wondering if these wheels will bolt up...
62bandit
Brian Taylor
Post by Brian Taylor »
Mustang bolt pattern is 5 X 4 1/2 our trucks if 5 lug have 5 x 5 1/2.
1966 Ford F-100 LWB 300
Uncle Skip
Post by Uncle Skip »
Brian is correct.
But Dodge truck wheels and 15" Jeep wheels will fit.
U@ss
62bandit
Post by 62bandit »
Thanks guys..
62bandit
slickmainer
Post by slickmainer »
Make-Model-Year-Bolt Pattern-OEM Wheel Size-Stud Size-Hub CenterBore-Offset
CHEVROLET/GMC TRACKER 1998 > 5 X 139.7
5 X 5.5 15 X 6 12 X 1.25 108.0
CHRYSLER ASPEN LIMITED 2WD 4WD 2007-08 5 X 139.7
5 X 5.5 9/16-RH 77.8
DAIHATSU ROCKY 4WD 1989 > 5 X 139.7
5 X 5.5 15 X 7 12 X 1.5 108 H
DAIHATSU ROCKY-4WD 1989 > 5 X 139.7
5 X 5.5 12 X 1.5 108
DODGE 1/2 & 3/4 TON TRUCK 1979-93 5 X 139.7
5 X 5.5 15 X 7 1/2-RH 77.8
DODGE DAKOTA 2005 > 5 X 139.7
5 X 5.5 9/16-RH 77.8 L/M
DODGE DAKOTA 2WD 4WD 2005-08 5 X 139.7
DODGE DURANGO 2004 > 5 X 139.7
DODGE DURANGO 2WD 4WD 2004-08 5 X 139.7
DODGE RAM 1/2 TON TRUCK 2 & 4WD 1994-01 5 X 139.7
5 X 5.5 1/2-RH 77.8
DODGE RAM 1/2 TON TRUCK 2 & 4WD 2002 > 5 X 139.7
DODGE RAM 1/2 TON TRUCK 2WD, 4WD 1994-01 5 X 139.7
5 X 5.5 16 X 7 1/2-RH 77.8 L
DODGE RAM 1/2 TON TRUCK 2WD, 4WD 2002 > 5 X 139.7
5 X 5.5 16 X 7 9/16-RH 77.8 L
DODGE RAM VAN 1985-03 5 X 139.7
5 X 5.5 1/2-RH 77.8
DODGE RAM VAN 1985-96 5 X 139.7
5 X 5.5 15 X 7 1/2-RH 77.8 L
DODGE RAMCHARGER 1979-83 5 X 139.7
5 X 5.5 15 X 6.5 1/2-RH 77.8
FORD 1/2 TON E-100, 150 VAN 1970-96 5 X 139.7
5 X 5.5 15 X 6 1/2-RH 86.7
FORD BRONCO 1966 > 5 X 139.7
5 X 5.5 15 X 6(7) 1/2-RH 86.7
FORD ECONOLINE E-150 VAN 2002-08 5 X 139.7
5 X 5.5 1/2-RH 87.0
FORD F1/2 TON F-100, 150 TRUCK 1954-96 5 X 139.7
5 X 5.5 15 X 6 1/2-RH 86.7 L
FORD F1/2 TON F-100, 150 TRUCK 2WD, 4WD 1954-96 5 X 139.7 5 X 5.5 1/2-RH 87.0
GEO TRACKER 2&4 DOOR 1989 > 5 X 139.7
5 X 5.5 15 X 6 12 X 1.25 108 H
JEEP ALL JEEP, CJ 1946-85 5 X 139.7
5 X 5.5 15 X 6 1/2-RH 108 L
KIA SORENTO 2003 > 5 X 139.7
5 X 5.5 12 X 1.5 95.3
KIA SORENTO 2WD, 4WD 2003-08 5 X 139.7
KIA SPORTAGE 1994-02 5 X 139.7
KIA SPORTAGE 1995-04 5 X 139.7
KIA SPORTAGE 94-02 1994-02 5 X 139.7
5 X 5.5 15 X 7 12 X 1.5 95.3 L/M
MITSUBISHI RAIDER LS, 2WD, RWD, DUROCROSS 2006-08 5 X 139.7 5 X 5.5 9/16 77.8
SUZUKI GRAND VITARA 1999 > 5 X 139.7
5 X 5.5 16 X 7 12 X 1.5 108
SUZUKI GRAND VITARA 1999-05 5 X 139.7
5 X 5.5 12 X 1.25 108.0
SUZUKI SAMURAI 1986-93 5 X 139.7
SUZUKI SIDEKICK 1989-96 5 X 139.7
SUZUKI SIDEKICK 1996-97 5 X 139.7
SUZUKI VISION 2007-08 5 X 139.7
SUZUKI VITARA 1998 > 5 X 139.7
SUZUKI VITARA 1998-04 5 X 139.7
SUZUKI X-90 1996-98 5 X 139.7
5 X 5.5 15 X 6.5 12 X 1.25 108
SUZUKI XL-7 2001 > 5 X 139.7
SUZUKI XL-7 2002-06 5 X 139.7
SUZUKI XL-75 1999-05 5 X 139.7
H = High Positive or FWD (Front Wheel Drive) typically +45, 40, 35 offsets
M = Medium Offset or RWD (Rear Wheel Drive) Typically +20 offset
L = Low Offset or RWD (Rear Wheel Drive) Typically 0 offset
--Gregg--
you can't get there from here
blackagatha
Post by blackagatha »
woah! all the newer Jap cars with the 5x5.5 amazes me!!!
