hadn't really planned on going to the swap meet Sunday, as there was considerable snow covering the ground, and it is an outside meet mostly. Finally left late to go, and arrived at just a little before noon. Surprisingly, it turned out to be a nice day. However, the vendors were packing up by the time I got there. About half as many vendors were there as normal, on a nice day. I mad some quick rounds and picked up those items I needed, basically some stainless wire brushes, and other odds and ends. I did buy a small block Melling oil pump for 10$, and a weller soldering iron for 5$. Also bought a small block roll around engine storage stand for 20$, and snagged a good 390 flywheel and clutch setup slightly used for 50$. All in all, it was good trip, and a nice day for it.
Cape Girardeau, MO. swap meet report
reeses66ford
- Johnny Canuck
- Johnny Canuck
The swap meet is an annual event and has been going on for a long time. fourty years I think. It is advertised in the St. Louis paper, and occurs every spring about the same time. When the weather looks to be good, it's one of the best in this part of the country, and there are some indoor spaces just not may. There are some outdoor spaces that are covered also just old stalls with open walls and some picnic covered areas. Usually a coat is neccesary, but sometimes not. Like I said it turned out very nice weather wise. However, the swap meet ends early about 3 in the afternooon, so you need to be there early.
