looking for tips
ebentraywick
- Uncle Skip
restoration
A related question: Did the 66's have dual master cylinders, or was it later?
I'd replace all the brake lines, steel and rubber as well as the gas lines. And wheel hydraulics. The gas line that run under the engine in the frame channel may be in bad shape. Also make sure you have the emergency brakes working good. I use mine all the time with manual transmission and slopes.
1961 caribbean turquoise flareside 223
jolly_roger63
Unis are a little different to restore etc. than the cab/box trucks when it comes to sheet metal issues. We can help you much more after some pics. When you get it home or get back to it make another post and I or somebody else can tell you what areas we need to see.
Can you weld? Have access to a rotisserie or enough space to get the body off the frame?
Not trying to intimidate you BTW.
jolly_roger63
