After taking a hiatus for a while I got the pumped changed out. Now it is running good.
I cleaned up the roof and floors so I could paint them. Here is what they looked like before.
After cleaning.
Now they are painted with POR15.
I did the same thing with the step wells.
I got the step wells painted with POR15 then top coated with truck bed liner material. I did not get a picture of that.
The floor got done as well. No rust holes in the floor pans.
I also got the air cleaner recessed into the inner fender. I need to come up with a 4 inch radius 4 inch exhaust elbow in order to connect the air cleaner to the turbo.
When I cleaned the roof off I discovered some nasty rust above the drip rail above three of the doors. I am trying to determine the best way to repair it. I need to get it sealed up so the inside will stay dry.
Well that's all for now. Once the roof is patched I plan on putting sound deadner and insulation up there. The same goes for the floor.
