63 uni
62galxe
63 uni
Post by 62galxe »
workin on this one
1963 uni PATINA BLUE
1965 short bed
ezernut9mm
Sweden
Post by ezernut9mm »
love that "far out" uni! lol. looks like you have a full plate.
62galxe
Post by 62galxe »
ezernut9mm wrote:love that "far out" uni! lol.
which one. :?
1965 short bed
ezernut9mm
Sweden
the first one, with the zany 70's side stripe and what appears to be mural art on the back of cab pillars.
62galxe
Post by 62galxe »
u think the outside is wild heres the rest of the piks.
http://fordtruk.com/forums/viewtopic.ph ... highlight=
1965 short bed
62galxe
Post by 62galxe »
nobodys home :lol:
block ready for machine shop
1965 short bed
62galxe
motor
Post by 62galxe »
almost ready to go in. 292- .060 over small cam 4 barrel carb G heads.
1965 short bed
62galxe
little bit more
Post by 62galxe »
Front end. Replaced kingpins,tie rods,draglink,wheel cylinders,brake shoes,brake hoses,brake lines and master cylinder.Check out the shocks. Appear to be original. felt good so im gonna try them out.
1965 short bed
castruck_1964
Post by castruck_1964 »
Good progress Ken
Looking forward to checking it out and chatting again at SS
Slicks rule
dd/ 19 F150,97 Tbird
62 swb bbw uni next project
460 C6
Ken
Anthony
Post by Anthony »
Lookin' SWEEEEEET!!!! I love the stripe and art work on that Uni....
62galxe
unprogress
Post by 62galxe »
putting a motor together is easy. building one right is a pain. getting in a hurry and tried to ignore the deck height. it bugged me to skip a important step in my rebuild. Pulled the heads off to check deck height. they were .043 in the hole. pulled it back apart to get the deck cut. that would have cost me a full point in compression. now I can put it together again. :oops:
1965 short bed
62galxe
Post by 62galxe »
got the motor back together. now just got to put the truck back together. no hurry. I still got 92 days. :lol:
1965 short bed
Michelle
Post by Michelle »
62galxe wrote:got the motor back together. now just got to put the truck back together. no hurry. I still got 92 days. :lol:
No pressure what so ever, you will get it done in time to spare. Looks really good Ken.
Michelle
62galxe
Post by 62galxe »
getting closer.
1965 short bed
Looking good Kenny!, don`t look up! it say`s 80 days! :D
Kenny hack it!, bet your life he ken! :lol:
62galxe
Post by 62galxe »
Motor and trans are together and installed. Got the alternator mounted. Working on alternator and duraspark wiring.
1965 short bed
62galxe
Post by 62galxe »
Finished up the brakelines, installed the rear brakes, removed the seat and gastank, cleaned the tank out, installed clutch linkage, and cut down the driveshaft and welded it back together. Had to steal the driveshaft yoke out of my 70 torino for the T5 in the truck. Now I just need universal joints. I like the way the banjo fittings worked out on the master cylinder. If you are careful you can drill and tap the bolt for the brakelight switch. Thats it for today and I am taking tomorrow off. You can get a lot done when its only 100 in the shade.
1965 short bed
olliesshop
Post by olliesshop »
Looking good!!! I have to do my brakes too. The pedal goes to the floor right now, so I'm going to completely redo the system.
Tim - 1961 F250 Uni
Michelle
Post by Michelle »
I like the idea of tapping the banjo fitting for the brake light switch.
Michelle
Post by Gritsngumbo »
Michelle wrote:I like the idea of tapping the banjo fitting for the brake light switch.
X2
