Old 2 ton trucks
- Paul Merrell
Old 2 ton trucks
Is there anyone into old 2 ton Ford trucks like back in the 20's or early 30's My father has this tractor car that he made in the 60's he calls it a shortdog. It had a 4 cylinder flat head engine but it has just be removed but it still has a 2 ton trans and the 2 ton rear end with dually rear wheels. This shortdog has been sitting I know 34 years and probally more. But if someone is looking for some parts we have them.
It sounds like a T or an A. If its an A it will have a distributor on the top that has wings out either side with 4 posts that connect to the plugs with steel strips. If it is a T it will have a "timer" round cap at the front, usually no water pump, just a fan run with a belt.
A engines were 28 to 31 and I believe there may have been a 4 cylinder option for a few more years but not sure. The T was from 1909 to 1927 and looked the same all the way through. Also had a wierd transmission in them as well, 3 small pedals and a large handle to the left of the pedals. The A is probably more sellable than the T but the T is harder to find in the truck.
Knowing what you have may make it easier to sell.
Hope that all helped
If it's a T dually let me know, I need to build a '17 flatbed that matches a picture I have of my grandfather beside his.
Dave
Dave
From a guy without his Ford that he left on a rock in the North Atlantic.
- Paul Merrell
Well I wish I had pics but I don't. Also the engine has been removed all thats left is the trans and the diff. This shortdog has a homemade frame a axle from a old dodge car and the old radiator was from a buick the seat was from a bus it is butt ugly. Dad and his father used it as a tractor. I know they just pieced it together with what they had.
there was a member named Mack from NC who had one he was working on, he was in a real bad accident and has not posted very much since, someone else from NC might know more.
