'66 Budget Slick: Tons of Pictures and Questions
shift_when?
Post by shift_when? »
This past weekend I picked up my '66 Slick. Drove two hours into the Ozark Mountains of Missouri with my buddy Jeff and visited with the previous owners for a long while. They have owned this truck for 30 some odd years and had some interesting stories to tell about the truck. They explained some of the dents on the hood were from a "playful" bull who decided to lounge on it one day. Other things we learned about the truck were that it has about 10,000 miles on its new 300 ci motor, a 4spd toploader, a year on a rebuilt front end (new bushings, cab mount rubber, steering bushing, etc). The truck is amazing and starts up the first time every time (knock on wood). She runs and drives like a champ!
Anyways, on to the business end of things. Jeff and I are in the process of fixing the front end where "Grandpa Whitey" sent a light duty Toyota to the junkyard. The truck came with all body parts to fix it, so we are just in the process of prepping and painting them as this is being posted.
On to the questions:
1.) Speedometer isn't working, and supposedly never has pre and post installation of the 4 on the floor. Here is the code for the trans: C9T3N-1 Waner Tran supposedly fitting the '69 F100-350. So, what do I need to inspect, replace, etc to get the speedo working?
2.) The next question is, what rear end do I have in it? The thing is a monster and were guessing the Ford 9", but hopefully this code can put me on track to knowing more about it: WDM-J 3:50/6?A 311
3.) The emergency brake isn't hooked up, and I don't think I'll be able to pass inspection with out it, and really would feel safer having it in operating condition just for peace of mind. So again, what to expect, install, look for, etc?
And finally, on to the much anticipated pictures!
Grandpa Whitey leaving the farm in St. Elizabeth, MO
Heading down the backroads towards Columbia
Me and my slick back in town after a 2 hour cruise.
Greasy Motor
shift_when?
More Pics!
Spare Fenders (comparing dirt on one, to cleaned up other)
Dirty Custom Cab
Unloading Spare Parts!
Body Work began tonight. Here is my buddy Jeff wet sanding the replacement front bumper.
Brian Taylor
Post by Brian Taylor »
Clean looking truck and welcome to the Slicks, it looks that Whitey use to be turquise. Just remember if you need anything for it let this group know.
I think most members have 1 running and 5 in parts laying around. :oops:
1966 Ford F-100 LWB 300
BarnieTrk
Post by BarnieTrk »
NICE SLICK! :cheers:
1.) Speedometer cable: C9T3N-1 Warner Trans from a '69 F100-350.
My information doesn't include such case marking. In '69, 2WD F100/350s could have been ordered a few different with New Process 4 speed transmissions, some have a 6-tooth and others have a 7-tooth speedo cable. I don't see a C9T3N-1 listed...you may want to re-check your number.
2.) Yep, your WDM-J 3:50 ratio rear axle is a Ford 9". What where did you get the - 6?A 311 from?
Is that extra data from off your Warranty Data Plate?
3.) The emergency brake system isn't too complicated and it IS nice to have in working order and normally necessary if you need to pass a State inspection.
You'll need to pull the rear drums off to see what is what........
BarnieTrk 8)
shift_when?
Barnie:
Thanks for the quick reply and helpful hints! The numbers off the trans / rear end are just those that were written on a piece of paper from the previous owner.. I guess I'll have to get under there and find the real #'s. Any hints on where they're at?
-Billy
BarnieTrk
Post by BarnieTrk »
Billy,
If you can't locate a tag on it, go here and try to match it up with these pictures and descriptions:
http://www.motivegear.com/tech_info/tra ... guide.html
Good Luck & keep us posted on your progress!
BarnieTrk :thumright:
lastwagen 66
Germany
Post by lastwagen 66 »
welcome.gif from North Texas....great Slick...nice job on the pics :clap:
Carl
“What we’ve got here is … failure to communicate.” The Captain, in Cool Hand Luke
‘66 F100 CC Styleside LWB 352, auto "Phoebe" SOLD 2011 - Gone but not Forgotten!
‘01 F-250 Super Duty Crew Cab, 7.3L , 2WD, SB "Crusher II" is my DD....330K and counting.... 9/08/17
Brians1966
Post by Brians1966 »
:thumright: good lookin Slick,
:steering: Enjoy
Brian
1966 F-100 LONG BED, 240cid 3 speed red and white, Red and White Interior with a Mossy Oak Seat Cover
2013 Ford F150 STX Supercab 5.0 litre
DETERMINATION: The feeling you get right before you try to do something incredibly stupid!
CONFIDENCE: Is the feeling you have before you fully understand the situation!
shift_when?
Thanks everyone!
So today I re-did the bumper, ended up painting it with semi-gloss black wheel paint. I did this with the idea that the wheel paint is tough against chipping, and it'll cover up some of the imperfections.
I also started going through the box of parts included with the truck. Looks like I have a speedo gear from ford, so perhaps I'll be able to throw that in and the speedometer will work?
BarnieTrk
Post by BarnieTrk »
shift_when? wrote:Thanks everyone!
Sounds like a good plan!
If it does, you've got better luck than I would have! :thumright:
I'd guess that the speedo cable is rusted/froze up inside......
BarnieTrk :steering:
Max
Post by Max »
Looks like a nice truck for starts. Are the floorboards covered with a mat or is that the metal showing? If so, they look pretty solid.
shift_when?
Max,
The floorboards are solid, but that is a green rubber mat that you see in the picture. It has since been cleaned up. More pics soon!
