Tim's 61 F250 Unibody restoration
olliesshop
Post by olliesshop »
Thank you Dan !!! If not, don't worry, I'll just order the ones from NPD.
Tim - 1961 F250 Uni
olliesshop
Yesterday, I only had enough time to degrease the engine/trans, but even that took about 2-3 hours, since there was 1/4" of crud on much of the bottom-side of the engine and most of the trans. It's pretty cool, since you can see the original markings on the engine and trans, which I've shown below. Now it's time to remove the accessories, sandblast and paint, which I'm guessing will take most of next week ... we'll see.
Tim - 1961 F250 Uni
Cool, the 223 is a good old engine.
I don't think I would sandblast it though. The sand gets EVERYWHERE and the inside of the engine won't like it.
olliesshop
I'm a little nervous about sandblasting it too, for the same reasons. What would you use to take the rust off then? There's tons of stuff on the internet, but maybe a good old wire brushing would work the best. Thanks.
Tim - 1961 F250 Uni
MadMaxetc
Post by MadMaxetc »
Make sure you de-grease it realy will and use metal=ready from por-15 or the equivilant from eastwoods. Then use 4 coats of high temp VHT engine paint on it. I did that to my 300 5 years ago and the paint on the block is still shinny black. I have about 20,000 miles on it.
My Build Thread
MadMaxetc
Post by MadMaxetc »
olliesshop wrote:Thank you Dan !!! If not, don't worry, I'll just order the ones from NPD.
I found mine. They are worn more that I thought. I would get new ones.
Sorry.
My Build Thread
MadMaxetc wrote:Make sure you de-grease it realy will and use metal=ready from por-15 or the equivilant from eastwoods. Then use 4 coats of high temp VHT engine paint on it. I did that to my 300 5 years ago and the paint on the block is still shinny black. I have about 20,000 miles on it.
That sounds like a good plan to me. Oven cleaner & some brushes will get rid of the grease & crud really well. My bellhousing had crud & grease that was over 1/4" thick cleaned up this well - bout an hours work.
olliesshop
Thanks again!!! ... my body shop paint store sells POR-15 so hopefully they'll have the Metal-ready also or something equivalent. Thanks for saving my engine guys ... I really didn't want ANY sand ending up in my engine. Also, I bought the VHT paints Friday and took about half of the accessories off the engine yesterday. Hopefully I'll get the rest off today or tomorrow and start painting parts and the the engine/trans.
Tim - 1961 F250 Uni
olliesshop
Here's how the engine looks today, with all the accessories, etc off it. I'm going to NPD and the paint store tomorrow to get gaskets, a fuel line that broke and some Metal Ready or something that will neutralize the rust and get it ready to paint.
Tim - 1961 F250 Uni
olliesshop
Sorry.
Thanks again ... By the way I drove to NPD yesterday and got a set. It was interesting, since first they were made out of some type of plastic and second, they were labeled Dennis Carpenter. So if anyone needs them too they could go right to Dennis Carpenter.
Tim - 1961 F250 Uni
olliesshop
Well today I spent the whole day doing final de-greasing with a wirebrush (toothbrush style) and lacquer thinner. Then I put on a coat of Metal Ready as you can see below. It's not dry yet, though, and I may have to put more coats on to fully neutralize the rust.
Tim - 1961 F250 Uni
olliesshop
Well I finally decided to order the stainless steel bolts set for my truck. I was afraid he was going to leave eBay or something, so I figured I better get them now ... http://cgi.ebay.com/ebaymotors/1961-196 ... 1c109eff20
Also, on the engine side, I got the engine and trans painted black on Thursday morning. Since then, we've been panicking with a 2 day Yard sale, of course to raise money for the truck ... hee hee. I'll post pictures later when I'm recovered from the sale, which just ended.
Tim - 1961 F250 Uni
MadMaxetc
Post by MadMaxetc »
Looking good. Should look realy nice when you are done.
My Build Thread
olliesshop
Well, here's some updated pics. I got it painted with VHT primer and black paint. Now it's time to restore each of the engine parts and put them back on.
Once again, here's a link to the progress album over the last two weeks ...http://feelc.smugmug.com/Family/Big-Red ... 7513_Dx7Mj
It's coming along, one piece at a time, but still a LONG way to go.
Tim - 1961 F250 Uni
olliesshop
Well the powertrain is all ready for bolting in (of course after a few months of storage, while I work on the body and some parts for my friend.) Still a ways to go ... It's coming along, though.
Tim - 1961 F250 Uni
Thunderboy
Post by Thunderboy »
Your engine looks terrific, Tim. Your grandpa would be proud! :)
Drew
66 F250 Frame swap, EFI 408W, ZF 5-speed swap (still!) in progress
63 Falcon Futura EFI 331W, T5, but not much progress... Slicks First!!!
slickmainer
Post by slickmainer »
i like it, black engine looks great!
--Gregg--
you can't get there from here
That looks really good.
ezernut9mm
Sweden
Post by ezernut9mm »
those manifolds are pretty!
64shortbed
Post by 64shortbed »
Wow! you did n excellent job! That will really set off the engine compartment. Seeing the results of your work makes me think about doing mine.
-don
'64 F100 262-I6
