63 uni
Wiring is done. Installed a steering column out of a 4 speed truck. No column shifter now. Stole the turn signal switch out of my other truck and got it installed. Turn signals and lights work
Cleaned and primered the cab floor to slow down the rust holes. Radiator is in.
. Attacked the carb with a grinder. throttle linkage fits fine now.
1963 uni PATINA BLUE
1965 short bed
1965 short bed
- dotcentral
the banjos came from here.
http://www.purechoicemotorsports.com/in ... prd107.htm
I drilled and tapped my own hole. You have to be careful drilling because it gets thin.
1965 short bed
1965 short bed
