1961 ford rat rod. f350
ebentraywick
Post by ebentraywick »
so ill be posting pics every few days 2 make you guys happy haha
owning a slick.,,, priceless :)
1961 ford f350
1959 ford f100. not a slick but still goood looking
]Image
ebentraywick
1961 ford f350
]Image
ebentraywick
1961 ford f350
]Image
thenephilm
Post by thenephilm »
What axle is that in the rear? Stock?
Looks nasty btw
ebentraywick
its a dana 60 from a 78 f250. thanks
1961 ford f350
]Image
If you are actually going to mount the springs like that I'm thinking;
You'll want to gusset those square tubing sring hangers pretty good.
Double the wall thickness where the spring bolts go through.
You'll also want to run some cross bracing before you hack the frame out between the front & rear ones too.
ebentraywick
yea im going 2 do a lot of bracing. and bolt and weld.
1961 ford f350
]Image
robert porterfield
Post by robert porterfield »
thoughts on where to run driveline?
lifes hard wear helmet!
ebentraywick
yea im going 2 channel the bottom of the cab
1961 ford f350
]Image
olliesshop
Post by olliesshop »
Cool ... this will be a fun thread to watch !!! :D
Tim - 1961 F250 Uni
