Nice truck
Thunderboy
I thought M referred to modified, because the Cleveland block was modified with a larger crank/rod journals (to 429/460 size, I think), and the deck height was increased. It also has the same bellhousing, distributor and timing chain as the 385 series. Add crappy large chamber heads and call it "M". The engine is testimony that "modified" isn't always improved, merely changed.
Drew
66 F250 Frame swap, EFI 408W, ZF 5-speed swap (still!) in progress
63 Falcon Futura EFI 331W, T5, but not much progress... Slicks First!!!
- ezernut9mm
depends on how hard you ride them...BarnieTrk wrote:Which one do ya think would give ya the most trouble?japedo wrote: If she comes with the truck I deffinentley couldn't afford it. One is expensive enough!
BarnieTrk![]()
BarnieTrk![]()
Who would give me the most trouble???? Probably my wife, unless she really liked the new f 100 girl. Then I might get jealous.....
There was some salvation for the 400's for a while. Someone in Arkansas was making a wider four V intake to fit the 351M and the 400's with the large ports so you could use the Cleveland 4V heads on them. I had a 78 Bronco with a 400 and it did not take a lot to liven it up.
Michelle
- stronger66ratfink
