Thanks, will try to get some updated pics this weekend.
Specs:
Engine: 223 I-6
Trans: Manual Column 3 Speed
Rear: 9" 3.89:1
Color: "V" Academy Blue
Built: Dallas (and seems to have spent most it's life in TX and CO)
The truck is very original and hasn't really been modified in anyway. I've been slowly working through the "issues" but we've been driving it every weekend. If it weren't for the manual steering and original drum brakes it would probably be a daily driver for the better half.
Done so far:
Fuel tank, lines/filter
Brakes, adjust e-brake
Ignition: plugs, wires, cap, rotor, points condensor
Carb rebuild
Interior parts
Left to do:
3 point seat belts (we live in South Florida!)
Radiator/Heater flush and new hoses
Get floor pan rust under control
Windshield
Figure out how to get old Ebrake handle off and new one on
Horn wire in column or contact plate has an issue
Figure out why high beams aren't working (new floor switch didn't fix it)
Door Seals and window anti-rattle
Find a suitable dry air cleaner for the Autolite 1100 to replace oil bath
Try to tighten up steering wheel play
Whatever else we come across
