Starting 352 in cold weather
Sixfootfour
Post by Sixfootfour »
Well, it was a fine day in Canada, today, only -6 degrees (Celsius), and I was waiting for the football game to start ( The Grey Cup ), and I thought I would try and start the 352 in the 1966 f-250.
I just rebuilt the 352 this summer and have never run it in the winter.
I wanted to add some antifreeze, and check the freezing point. Sure enough it was only good for -15, so I drained some out and added some more antifreeze.
To my surprise, the truck started easily and idled right away. The oil pressure was pretty high, about 80 PSI, because I used a high volume pump during the rebuild. The 4 bl Edelbrock carb , with electric choke was working properly, and no stalling.
I let it run for a while to open the thermostat, and charge the battery.
The old girl runs OK in the winter.
And now I'll watch the game, on TV, at home ( a lot of people are downtown watching it being played outside )
It was a fine day in Canada.
63 Uni
73 Mustang 351C
74 Dodge Charger
76 Granada 2dr
Gary Seymour
Post by Gary Seymour »
Brrrr. I'll bet the ol' truck appreciated the warm feeling!
Anthony
Post by Anthony »
Can't wait to hear mine run..... congrats on the excellent rebuild!! enjoy the game... :thumright: :thumright:
We have come to think that with the EFI, engine management, etc. that all these new vehicles are better than the older stuff. Your modern stuff is efficient and easy - no letting warm up, no choke etc. Fire it up and drive.
The newer stuff has MUCH more to go wrong though too, a battery that will run your old truck just fine could be marginal at best for the demands of a newer car.
Everybody thinks only front wheel drive cars get around in the snow BULL___T, the only fwd cars when I learned to drive were unless you could afford and Eldorado or Toronado.
My old blue 64 lwb that everybody I knew used to make fun of, people would look at it with disgust, ex wife & kids didn't want to ride in it.
Mind you if it got really cold out and nothing else would start this is what we got around in. Nobody was laughing then!
New stuff isn't "better", we have just - forgotten.
Like so many other of the important things.....................
aarons428
Germany
Post by aarons428 »
Boy u are lucky my 428 will NOT start anything below 40. Oh well i dont have a heater in it anyway.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
62galxe
Post by 62galxe »
mine was a little cold natured at 30 F but I have no choke at all.
1963 uni PATINA BLUE
1965 short bed
aarons428 wrote:Boy u are lucky my 428 will NOT start anything below 40. Oh well i dont have a heater in it anyway.
Yours isn't you average driver FE.
The average FE doesn't run 12s in the 1/4 in a truck either.
I think you again for that ride,
it's been a long time since I've been in something like that.
Sixfootfour
The choke and high idle are working, and it has a new heater core, as well as a block heater, but it was not plugged in today, with the mild weather.
Montreal won the football game against Saskatchewan, final score 21 to 18
Final temperature -9
63 Uni
73 Mustang 351C
74 Dodge Charger
76 Granada 2dr
64shortie
Post by 64shortie »
My old, dependable, manually choked 292 has never failed to start. Last winter it wanted to stall after idling for about ten minutes. Figured out that was a vacuum leak. Fixed that and no problems since. Throw a little weight over the back axle and the thing goes through snow like a tank. The fancy, supercharged, high tech, front wheel drive Bonneville always started too, but, in snow anything over four inches it becomes kinda helpless. The Slick gets a lot of winter use.
Love those little square trucks
64 F100 short cust. cab
Custom built Harley FXSTC
2000 supercharged Bonneville
Effie
Post by Effie »
Greg D wrote:
New stuff isn't "better".............
No kidding. I told my Aunt I was selling my Fusion. She said she didn't mind, long as I got something new-ish and reliable. I just grinned, like, yeah, ok.
That ol ratty, noisy Bronco has never let me down in the 5 years I've been driving it. I don't drive the '66 as much, so I can't say, but its never let me down either and that FE busts off on the first click of the switch every time.
New. Pppsh, my ass. I'll keep my old trucks. I feel safer and happier in them.
~/\/\elissa~
Image '66 F100 -- Little Black
Image '78 Bronco -- Brutus
64shortie
Post by 64shortie »
Besides, they're a heck 'uv a lot cuter.
the 223 in my truck starts in cold weather no problem
and talk about reliable....
the CHECK ENGINE light has never came on ..... :D
charliemccraney
Post by charliemccraney »
I don't know about really new stuff, but '80s stuff is easy. If I have a problem with my car, 1988 Firebird, I plug in my laptop, take a look at all of the sensor readings, find the one that's not functioning or reading out of spec and go from there. In many ways, it's easier. It's really just a matter of having the right tools and in this case, the tools aren't expensive. Probably the only thing you will have to pay for is the interface cable. This day and age, almost everybody has a computer of some sort. If not, laptops that will do the job can be found real cheap. The software is free. The only really "complex" system on it is the engine management system. Everything else is treated as if it is a car from the 50s or 60s. Very simple. Some of the problems I have had with my truck make me wish I can just plug a computer to it to see what's going on.
The thing I hate about newer cars is the plastic. After 20 years or so, it seems that there is no way to remove plastic without breaking it.
With that, I will say newer stuff isn't worse, either.
Lawrenceville, Ga
1961 F100 Unibody
