Hi, I have started to assemble my irs diff for my '64' and i want to share some photo's Darren.
au falcon diff,narrowed 4 inches,fitted with dutchman alloy 9in housing with 35 spline 300m axles,strange nodular centre,fitted with 4-11 gears,yukon ratchet locker,
I'm not sure how heavy it is.
my friend gave me a hand to put it on the bench before it had the centre in it,at a guess it weights one and a half of the factory 9in,
OK time for 20 questions - what is that irs out of? What does it look like mounted under the truck? pics, pics, pics! Man, I want to do this to mine sooooo bad.
Thank you, It came out of a 2004 au ford falcon xr8.
It looks really good mounted under it and with cut and shut I did on the rear chassis it dropped the truck along way,
i will have to look for pic's and I will post up
We don't see to many '04 falcon XR8's around these parts! Guess I'll have to settle for a t-bird or Explorer. Will wait impatiently for those pics, though!
64low-n-slow wrote:We don't see to many '04 falcon XR8's around these parts! Guess I'll have to settle for a t-bird or Explorer. Will wait impatiently for those pics, though!
Check into the MArk VIII IRS. I just sold the IRS out the Mark VIII that I took the engine and trans out of. I sold it for $150. I couldn't find anybody that wanted it so I let it go that cheap. They are out there if you look around.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
This place sells brackets to use the Thunderbird/Mark VIII IRS. You will also have to change the lug pattern to 4 1/2", its a weired 4 1/4" pattern now. http://team321.com/truckirs/truckirs.html
