Power antenna
loosrp
Power antenna
Post by loosrp »
Anyone one here put a power antenna in the factory cowl position? If so what did you use and where did you puchase it? I wish I just would have welded that hole up but it's to late now..
Russ
MadMaxetc
Post by MadMaxetc »
I have seen them insatlled in many other cars & trucks....but not a slick.
I have seen people mover there antenna inside using one of those hidden ones. To fill the hole they used the little chrome plug that fills one of the switch holes in the dash. They used some seam sealer to seal it up. Also seen one painted to match.
My Build Thread
MadMaxetc
Post by MadMaxetc »
I plan to french a powered on into a little cup where the gas filler is now.
Going to move the gas tank behind the rear axle.
My Build Thread
F7BIGJOB
Post by F7BIGJOB »
There isn't enough room to put one on/thru the cowl is there?
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
61ford
Post by 61ford »
i seen one for sale on ebay a yr or two ago that was suppose to fit and went in the factory spot
Ryan
61 Ford f100 Unibody short bed
351w/Aod
loosrp
Post by loosrp »
Thanks for the replies, anyone else?
Take a look at one of the compact units made for street rods. If you can get it into a Model A cowl it should fit in a Slick's.
MadMaxetc
Post by MadMaxetc »
Don't you go through the vent doors on the inside?
My Build Thread
loosrp
Post by loosrp »
Yes, I would go in thru the pass side vent hole.
Uncle Skip
Post by Uncle Skip »
Personally, I don't want anything outside the truck that some cretin can come along and screw up. My antenna is mounted to the inside of the windshield.
U@ss
[albumimg]8939[/albumimg]
[albumimg]8940[/albumimg]
aeromech
Power antenna in '65 F-250
Post by aeromech »
I installed an aftermarket power antenna in the right cowl panel working through the passenger side foot air vent and heater duct openings. As I understand it the antenna were dealer installed so the location the the hole may varry from truck to truck. Installation came out nice and clean and protects the antenna when not extended and makes use of a car cover much easier.
loosrp
Post by loosrp »
[quote]Personally, I don't want anything outside the truck that some cretin can come along and screw up. My antenna is mounted to the inside of the windshield.
Thus the reason for adding a power antenna..[/quote]
