Front clip removal....
63Longbow
Post by 63Longbow »
Did a search for fender removal, what i'm lookin for is the process in removal of the front clip grill on back.
What started this i removed the rear axel replaced bearings, seals breaks breaklines and removed 3 of the 9 leafs along with the bushings. That went so well, i'm going to attack the front. Want to remove the grill inner and outter fender and work my way in......just how many bolts....and nuts are there, that hold that fender on?
1963 F100 223ci 4 on the floor T18 stepside Az. truck
Mark Mitchell
61 Merc
Post by 61 Merc »
Uncle Skip just recently did a posting about removing the front clip. It is in the hints and tricks section. This is the link to his post.
http://fordtruk.com/forums/viewtopic.php?t=19737
Hope you enjoy this proceedure, much easier pulling the whole clip then pulling it apart.
Dean
61 Mercury SWB Uni - Project
63 Ford SWB Uni - Parts truck
yes much easier to remove the whole thing and then dismantle it on the floor/ground.
foodstick
Post by foodstick »
Step one of a first time front clip take down is ...scratch and cut and bruise your whole body ...and cry rust filled tears !
Just having fun, read the listing of Skips for real help.
I will guarantee that you will find yourself pacing the floor with a hammer in your hand, mumbling cuss words..at SOME POINT ! :lol:
HiBoy63
Ireland
Post by HiBoy63 »
Also go to napa walmart or your favorite auto parts store and secure at least 4 cans of rust buster brand penatrating spray. The 4 cans is just a suggestion depending upon where you live within the continuous united states or canada or anywhere slicks are found.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
63Longbow
Big help....
Post by 63Longbow »
Thx. for the info. on removing the whole front, and a great write-up. Found all the bolts 3-4 of the hidden bolts came out need to cut ...grind, torch kept cuttin out ( no O2) torched the two big ones in the front, just need to pop the bumper off tonight, should be off Sat. morning.
Thx again,
Mark
