I need something explained to me
kid2
Post by kid2 »
Ok here goes. I have been wondering why you lose vacumn when you put a high performance cam in. I know how and why the engine makes vacumn but don;t understand why a engine creates lees with a Higher performance cam. keep the explanation simple guys.........kid
65 f-100, Mostly Stock
64 F-100, 4in roof chop and on a car frame
64 F100, Project, not sure what to do with it
61 Long Uni project
79 F-250 Super Cab Long Box
74 Duster, Future Project
Dropped,Chopped,Tubbed,and Stubbed is the way to go
It is easier to ask Forgivness than to ask Permission
Bills 66
Post by Bills 66 »
It is caused by the valve opening and closing points in relationship to top dead center and valve overlap, the amount of time the intake and exhaust valves are open at the same time. It also reduces the effective compression ratio allowing more of a static compression ratio to be used with the same octane gas without detonation. To explain any further you have to get into the basics of how a four stroke engine works. Cam "science" is mystical. What looks good on paper is not always good in reality and what works well in one engine (289) does not always work well in another (390) ect.
banjopicker66
Post by banjopicker66 »
I'll try too:
When the piston is pulling in air it creates suction or vacuum.
They reshape cams to make valves open and close earlier or later to improve air intake, depending on the engine and application such as high RPMs versus high torque.
Only so much air can be sucked into the cylinder in a given amount of time. Physics won't allow air to flow faster. However, when the engine is running faster, the amount of time is greatly reduced that when it is running slower. It has to get the same amount of air in, but it has less time to do it at 3000 RPMs than it does at 800 RPMs. So, they re-design the cam to open the valve a little earlier, stay open a little longer, and close a little later (or some variation, depending on the design.)
A good way to think of it is small garden hose and a larger water pipe. If you put a gallon a second through the hose, it cannot handle it, that's too much for too small a passageway. If it could, it would be under very high pressure. You can easily put a gallon a second through a 6 inch pipe, though, and it would be under much lower pressure.
Same with air into the engine, the air passages can only allow so much air.
Too little vacuum means too much air is getting through, and too much vacuum means too little air is getting through.
They extend the valve open times to get more air in when the engine is running faster.
So, with a cam that is designed to get more air in at high RPMs, it runs poorly at idle, but wakes up at higher RPMs.
They also take into account the exhaust valves too, and that has an effect on how it runs.
When the valve opens earlier or closes later it reduces the amount of suction, because the piston sucks in more air.
I hope this helps and isn't confusing!
